Powered rear window help
Powered glass not original to the car the patient is a company that makes windows guy was fired company unresponsive
Anyone ever work on one of these or have an idea of how to repair? Motor works glass is held up by screws I assume there's some kind of scissor arm missing? Belt at the bottom is stuck but theres tracks on both sides
A very common window motor: https://www.rockauto.com/en/parts/ac...dow+motor,1516
And when I look up that patent, I see it is for a bench: https://patents.justia.com/patent/D467101
There is a 3 at the end you can't see I realized here are some screenshot from the patent
unfortunately, Im going on vacation later today and this will be put on pause for when I return in 2 1/2 weeks. The glass is out of a Ford Bronco tailgate glass with some altercations the tracks are out of a gm so with some know how someone could replicate this system out of these drawings these parts are easily obtainable out of AutoZone switch I found on amazon just a standard up down window switch
Ive ordered the window tapes and am sourcing a rubber elastic band for the window, more updates after some fun in the sun
The tape tracks were hard to find in the end
You should be able to find new track parts for your rear window on Ebay maybe
Find a Centurion or ARA upfitter
That is who used to make and install those IIRR
I've seen kits for power sliders, but not the whole window.
Ford put a window like this in the Bigfoot model trucks I believe. Or a system very similar.
The thing about the ubiquitous sliders is, they usually work. They sometimes leak, the latch breaks, but the glass doesn't drop to the bottom of the cab.
t
just jealous he doesn't have one.
