Shifter rough to move.
Old Jul 25, 2024 | 12:13 PM
TheTowingCowboy's Avatar
TheTowingCowboy
I have just acquired a 2003 Excursion with 6.8L V10. This is the first time I have ever dealt with a Ford shifter that was the opposite of sloppy. It’s stiff and feels like it drags from position to position.
I seem to remember years ago guys having problems with the TRS, which I plan on swapping out cause it’s reasonable cheap. Is there anything else anyone can think of that could cause this? Gonna try and soak the cable down to see if that helps (sure can’t hurt)
Appreciate any and all insight.
Old Jul 25, 2024 | 05:22 PM
01__Excursion's Avatar
01__Excursion
Maybe someone added to the bushings in an attempt to correct the looseness? You can look through my post of when I replaced the worn parts, and tightened the loose ones to see if there is something different.
https://www.ford-trucks.com/forums/1...l#post20472694
kimara3002
Oct 12, 2016 06:38 PM
RangerPilot
1983 - 2012 Ranger & B-Series
Jun 4, 2006 07:41 PM
bigpowerstroke
Nov 25, 2004 12:27 PM
