Sponsored by: Auxito
Transmission info?
Old Jul 24, 2024 | 09:36 AM
waldo16's Avatar
waldo16
Transmission info?
Does anyone know what transmission is in a 97 F150 2WD 4.6 V8 and the fluid capacity on it?
Old Jul 24, 2024 | 09:42 AM
RLXXI's Avatar
RLXXI
4R70W for 2 wheel drive, 14 qts includes draining the torque converter, it has a drain plug you have to align with the hole in the bell housing to get at it.
Old Jul 24, 2024 | 09:48 AM
waldo16's Avatar
waldo16
Do you know the capacity without draining the torque converter? I’m just replacing the pan gasket
Old Jul 24, 2024 | 09:55 AM
RLXXI's Avatar
RLXXI
4 qts to start, then fire it up and check the level.
Old Jul 24, 2024 | 10:06 AM
waldo16's Avatar
waldo16
Is it necessary to us Mercon V or are there others I can supplement in place of Mercon?
Old Jul 24, 2024 | 10:11 AM
RLXXI's Avatar
RLXXI
Going from the shop manual: Use MERCON Multi-Purpose Automatic Transmission Fluid or equivalent meeting Ford specification XT-2-QDX or DDX. Merc V should be fine.
Old Jul 24, 2024 | 11:05 AM
waldo16's Avatar
waldo16
Is Mobil1 ATF Multi-Vehicle alright to use? Mercon ATF is expensive lol
Old Jul 24, 2024 | 11:50 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
MERCON AFT hasn't been made since 2006. You won't find it anywhere. MERCON V is the correct fluid. Many different companies sell MERCON V fluid, you don't have to use Motorcraft.
usafstud
1997 - 2003 F150
Feb 18, 2021 01:04 PM
blownstude
Sep 12, 2006 11:21 PM
1997 - 2003 F150
Sep 28, 1999 04:18 PM
