Clutch/tran help?
Old Jul 23, 2024 | 10:25 AM
Sweet Tony's Avatar
Sweet Tony
4wd Low
Clutch/tran help?
Hey, newbie here. My 59 f100 has a T98 4 speed. When the car is off it shifts fine but going down the road 3rd and 4th gears are hard to find...lots of grinding. I have put in a new clutch master and slave cylinder. Is this grinding mean I need a new clutch or new shift linkage or both? Not sure how old each part is but the engine is a 1963 223 and it may be the original clutch.
Old Jul 23, 2024 | 07:01 PM
spurredon's Avatar
spurredon
Have you tried just adjusting the clutch to give it a little more movement?
Old Jul 23, 2024 | 07:30 PM
Sweet Tony's Avatar
Sweet Tony
4wd Low
Didnt really know that was a thing. Does it matter that it is hydraulic and not mechanical? Either way, ill look it up and give it a go. Thanks!
Old Jul 24, 2024 | 12:54 PM
Byrd.Dog's Avatar
Byrd.Dog
You should be able to loosen or tighten the two nuts that attach the slave rod to the shift fork to make the throw longer or shorter.
Old Jul 24, 2024 | 03:21 PM
FuzzFace2's Avatar
FuzzFace2
I would also check the lube / oil level in the transmission.
I am guessing it would take 75-w90 gear oil.
I have found draining the old oil and refilling with Red Line M-90 my NP435 shifts a lot easier.
Now the NP435 transmission was bought used to replace a vary worn T18.
This replacement is a little hard going up and down into 3rd gear.
It was better with the M-90 lube but still can feel it grind a little.
I just double clutch when going up or down into 3rd makes it a little better and been this way for 28K miles.
I just dont force it into gear. If it dose not go in I double clutch again and that dose the trick.
I know my clutch assy. is good, 28K on it but may need to adjust it a little.
Dave ----
vektron75
Feb 23, 2012 06:37 PM
84-F150
Apr 15, 2008 01:00 PM
hartattack
Apr 11, 2004 06:40 PM
hartattack
Apr 4, 2004 09:39 PM
