low clutch prob, help
Old Apr 10, 2004 | 07:25 PM
hartattack's Avatar
hartattack
i just had put in a new clutch and pressure plate for my 86 f150 and also a new slave cylinder. the clutch remains extremely low and practically have to put it throw the floor to change gears. the mechanic said it doesnt have a adjuster nad that the clutch will have a just as long as a life as if it higher. is this the truth? the clutch has always been alittle low, that thats when i couldnt shift it before and they said i needed a new clutch. now i'm thinking that the old clutch may still have been good but just needed adjusting if that can be done. any help out there?
Old Apr 10, 2004 | 07:32 PM
zieg96's Avatar
zieg96
The firewall gives way where the clutch master is located. Spotwelds break. Have someone push in your clutch and you check under the hood and see if there is movement.
Old Apr 11, 2004 | 05:42 AM
hartattack's Avatar
hartattack
how do i fix if thats the problem
Old Apr 11, 2004 | 08:27 AM
zieg96's Avatar
zieg96
I ran self tapping screws through it near where to spot welds broke. Just be carefull not to hit anything.
Old Apr 11, 2004 | 06:37 PM
hartattack's Avatar
hartattack
i am i looking for wear the clutch pedal comes in coontact with the floor, i'm clueless. where is the clutch master located?
Old Apr 11, 2004 | 06:40 PM
Bob Ayers's Avatar
Bob Ayers
The clutch pedal linkage goes directly to the clutch master cylinder. The master cylinder is mounted on the engine side of the firewall....
