squeacking from under truck
Old Jul 22, 2024 | 03:45 PM
seth.goose's Avatar
seth.goose
6th Gear
i recently bought a 1983 F-250 6.9 idi, 4x4 4 speed manual, havent really had any issues but i noticed today that when im idling at a stop i can hear a squeaking sound, i thought it was the belt as it would go away after accelerating, but it wasnt the belts and sounds like its coming from under the truck somewhere, idk what it is and was hoping for some advice, thanks!
Old Jul 22, 2024 | 04:20 PM
Hawkbox's Avatar
Hawkbox
Does it sound like a metal on metal squeak or a belt squeal as you were theorizing? Could be your suspension settling while you're stopped? I know mine makes some weird creaking noises when it goes over uneven terrain and I'm pretty sure it's my front coil springs.
Old Jul 22, 2024 | 07:10 PM
seth.goose's Avatar
seth.goose
6th Gear
it’s like a belt squeak, i don’t believe it’s suspension related, i let it sit for about 10min idling and came back out and was still squeaking so i’m not sure
Old Jul 22, 2024 | 07:12 PM
Hawkbox's Avatar
Hawkbox
Yeah that definitely sounds more like a belt issue. Trying to think what else could be making a squeal/squeak rather than a scraping noise. Do you have AC? Might be the other belt? Could be a bearing maybe...? My truck has 2 on the alternator and 1 on the power steering.
Old Jul 22, 2024 | 08:10 PM
seth.goose's Avatar
seth.goose
6th Gear
yes i do have ac but it does not currently work, possibly a transfer case bearing from what i was reading but i went and started it and isn’t making noise antmore so i’m not sure
Old Jul 23, 2024 | 07:46 AM
Bronco638's Avatar
Bronco638
If you think it's belt-related (coming from the front of the engine), it could be the water pump bearing and/or the fan clutch (if you have one). Alternator maybe? Power Steering pump?
Old Jul 23, 2024 | 07:00 PM
FuzzFace2's Avatar
FuzzFace2
What is the oil level in the trans & transfer case?
When under the truck check the oil in the front & rear axles too.
Dave ----
Old Jul 23, 2024 | 08:13 PM
seth.goose's Avatar
seth.goose
6th Gear
Dave ----
i have not checked. i’ll do that tomorrow morning
thanks!
Peace2Peep
Mar 18, 2016 11:02 PM
themdgx
1983 - 2012 Ranger & B-Series
Sep 1, 2012 11:01 AM
bduemig
Aug 19, 2010 10:08 PM
dakejh
Sep 15, 2003 11:44 PM
FordCowboy2000
1997 - 2003 F150
Jul 17, 2003 12:09 PM
