Thought you guys would like to see this, it is available at any Ford dealer, great for owners who did not have this option available at purchase. This product is extremely easy to install! It programs in to your existing remote entry system just like a remote. Pricing is $135.71 list each, can be discounted for packs of 5 or more.
Fits all these vehicles with 1 part#.
To: All Ford and Lincoln Mercury Dealers
Subject: 2003 Accessories - Keyless Entry Key Pad Launch
GREAT NEW ACCESSORY PRODUCT AVAILABLE TODAY!
Genuine Ford Accessories is proud to expand its accessory offerings with the latest in universal keyless keypad technology. This keypad can be installed with vehicles that are equipped with factory remote keyless entry systems and may provide functionality similar to existing factory keyless entry systems. The new Keyless Entry Keypad:
Has only one part number
Installs in minutes with no drilling, wiring or tools required
Is single unit retail packaged with tri-lingual instructions for easy
installation
Will work with most new or used Ford Motor Company vehicles
APPLICATION CHART
The following is a listing of all vehicles that can be outfitted with
this new exclusive Ford Motor Company technology. (Please note that the vehicle must have existing factory remote keyless entry to work.)
Absoulutley could not be easier.... Do not let Ford charge you for installation, Turn key from OFF to RUN 8 times in 10 seconds, 8th time ending in RUN, all doors will lock and unlock to confirm programming status, within 20 seconds press any button on remote, then again as nec with other remotes, key to off, done.
So basically this system is a stick on keypad that goes in the factory location on the door. It is programmed via the keyless entry on the vehicle. It requires a battery similar to the one in the key fob remote. Next and last question......can it be used on a 97 Expedition? Does anyone have a picture of the unit?
I just bought a keypad for my 2000 F-150.
Reading the threads, it sounds so simple...OFF to RUN 8 times.
I've tried this several times and it still does not cycle the locks.
What can I be doing wrong?
Any ideas?
Appreciate the help.
JT
WOW an old thread.......Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Being new to the forum, I'm hoping someone can help. I'm in a similar situation as Sunshine_Ford. I have one installed on a used F250 I bought. I did learn something that may be helpful. When turning the key on and off 8 times you have to do it VERY fast. Like 8 times in 8 seconds fast this does cause the door locks to cycle. BUT, once I do that, I enter the code I want to use, turn key back to off and nothing. Does anyone have the actual instructions for the keyless entry they could scan and email to me? THanks in advance.
