IWE issue I think
Old Jul 18, 2024 | 07:30 AM
deweyg63's Avatar
deweyg63
1st Gear
IWE issue I think
2017 F350. 115K miles. Recently started getting what I think is the IWE grinding. This started shortly after having the ball joints replaced so obviously the front end was torn down for this. The noise seems to come from the left side and it is intermittent. It will start after driving awhile. Switch to 4H does not change or stop the noise. Breaking doesn't either. Coming to a stop and taking off again does stop the noise. I'm thinking of unplugging the solenoid to see if the noise comes back when the hubs should be fully engaged without vacuum. Thoughts or experience with these symptoms?
Old Jul 18, 2024 | 10:43 AM
Phillbo's Avatar
Phillbo
Try posting this on the F150 site if you get nothing here. They have a dozen IWE noise threads daily.
Old Jul 18, 2024 | 12:01 PM
wheelerfreak's Avatar
wheelerfreak
IWE on a 2017 F350? IWE’s were on 150’s, the 350 should have vacuum hubs with manual override. IWE default to locked when you lose vacuum, so if it’s a 150 they could have forgot to reconnect the vacuum line. If it’s a 350 they could have put the hubs back together wrong.
Old Jul 18, 2024 | 12:39 PM
muisejt's Avatar
muisejt
Super Duty uses CVH (continuous vacuum hublocks), no vacuum is unlocked and vacuum is locked
F150 uses IWE (integrated wheel ends), vacuum is unlocked and no vacuum is locked
Roadtriptruck
Jun 14, 2016 12:34 PM
bflora
Feb 6, 2016 05:56 PM
SUPERDUTY OUTLAW
Jun 15, 2009 05:43 AM
jater76
Apr 17, 2007 10:50 AM
351fordpower
1997 - 2003 F150
Apr 4, 2006 03:23 PM
