Intake bolt
Old Jul 12, 2024 | 02:51 PM
Anonymous12's Avatar
Anonymous12
Intake bolt
I took the intake bolt out since it looked like it was a pain. It was easy to get out I just fished it out from below with a magnet. But there’s not a gap big enough to get the stupid torx bolt back into its hole. How do I get it in? The stupid EGR nut is stuck so I can’t reseal the intake today so I gotta put it back together
it’s the head of the bolt that isn’t fitting through the gap.
Old Jul 12, 2024 | 03:29 PM
jas88's Avatar
jas88
You set the bolt in the upper intake and then drop it on top of the lower.
Old Jul 13, 2024 | 12:31 AM
seschenburg's Avatar
seschenburg
I agree the gap in the manifold should be bigger, but you'll probably just have to reverse the procedure you used to get it out. Or, if you have someone, like a child, with small hands, they may be able to get it into place.
Old Jul 13, 2024 | 08:04 AM
matkinson13's Avatar
matkinson13
Here's what i used to remove and install that bolt:
It's magnetized so it could hold the bolt on extraction and installation. I used a 1/4" drive ratchet with 1/4" socket but you might use a drill or impact driver.
Good luck!
Old Apr 8, 2026 | 08:35 AM
dremtofford's Avatar
dremtofford
i reach underneath to put the torx bolt in.
willeye78
1997 - 2003 F150
Jul 15, 2020 10:15 AM
skidmarks82
1997 - 2003 F150
Jan 9, 2013 08:54 PM
neevnav
Apr 14, 2007 07:55 PM
greybullit
Dec 2, 2005 03:53 PM
hatcatz
Nov 20, 2005 08:54 PM
