Belt squeaky sound
Old Jul 11, 2024 | 11:15 PM
6.0Ruso's Avatar
6.0Ruso
Trailering
Belt squeaky sound
A while back I discovered a squeaky sound come from where my serpentine belt is. Not to long ago, I had replaced the water pump and belt tensioner. Replaced the belt tensioner because I thought maybe the squeaking would stop then. Also replaced two idler pulley bearings as well. Serptine belt was replaced about 5k miles ago. And the squeak still continues to this day. Not sure if it's other pulley bearings or what? Any one have any suggestions? Fairly new to diesel engineering but I'm learning every day, go easy thank you🤝
Old Jul 12, 2024 | 07:16 AM
TooManyToys.'s Avatar
TooManyToys.
Relieve the tension on the best and start it for a few seconds to see if the noise is from the belt.
Also, if the water pump pulley is too polished, it can sometimes slip. The surface can be roughed up with coarse sandpaper.
What brand of belt are you using?
Old Jul 12, 2024 | 08:28 AM
6.0Ruso's Avatar
6.0Ruso
Trailering
When I had removed the water pump pulley, I cleaned it out completely with a small sanding wheel. Don't remember the brand but it was purchased from the local NAPA auto parts store.
Old Jul 13, 2024 | 01:26 PM
Johnny Bravo 45's Avatar
Johnny Bravo 45
An old hot-rod trick which works well for squeaky belts is to soak your belt in some armor-all. My belt used to squeak, I spray armor-all on the belt when it's running and also spray it down when the truck is off. My belt never squeaks anymore, granted the belt is the source of the noise.
Dennis Anderson
Dec 17, 2014 04:46 PM
dcara
Aug 31, 2007 01:24 PM
70T351W
Jan 29, 2007 08:27 PM
Baumer
Jun 20, 2006 03:20 PM
semperfipsd
Dec 10, 2004 11:15 PM
