Another tire psi question
Old Jul 7, 2024 | 10:25 AM
Harry24's Avatar
Harry24
Trailering
Hello all,
I just picked up a 24 350 xlt 4x4 ccsrw 7.3 with 275/65/20 Bridgestone Dueler A/T's. I have spent the past few nights reading the threads regarding tire psi. This truck will not be towing and the most payload in the bed would be luggage for vacations. No off roading, just asphalt, mostly highway miles. Without needing forscan what would the best psi be for a decent ride without affecting mpg and tire wear? I know this topic has been beat to death but the more threads I read the more confusing it became. Thank you all in advance.
Old Jul 7, 2024 | 10:31 AM
scraprat's Avatar
scraprat
Top Answer: 5
Originally Posted by Harry24
Hello all,
Most likely you'll get the same in this thread from 40 psi like a passenger car to 65 psi +/-. I'm a 65-70 psi guy and think it rides great at that amount but have always had F250/ 350s were it seems now folks coming from cars want a car ride in a heavy duty truck.
Old Jul 7, 2024 | 11:11 AM
4wd6.7L's Avatar
4wd6.7L
Hello all,
Without using Forscan to lower the TPMS threshold, you can only go down to about 20% below what is recommended on the door sticker. More than that will set off the TPMS light. So if your rear tires call for 85 psi you might be able to run a cold PSI of 68. You'll have to experiment or pick a number and maybe live with the warning light.
I aim for 55 front, 50 rear in my CCSB 6.7l SD. Even at 50 psi mostly the center section of tread is making contact. I might try 45 in the rear to see if that improves.
Old Jul 7, 2024 | 11:37 AM
shawnee1's Avatar
shawnee1
Sorry, but I have to ask. No towing and a couple hundred pounds at most in the bed; so why an F350? Don't get me wrong, I'm not judging your choice, just wondering why. An F150 would more than meet your payload needs and would give a better ride and much better fuel mileage.
Old Jul 7, 2024 | 11:47 AM
Harry24's Avatar
Harry24
Trailering
The 350 was sitting on the lot for awhile so the dealer was willing to deal on it plus the 150's are everywhere. We wanted something different. I know its overkill but boy the Superdutys are fun.
Old Jul 7, 2024 | 11:58 AM
4wd6.7L's Avatar
4wd6.7L
My field of work does include the potential that I could have a load in the bed, or more rarely, tow something. But even in those instances my 250 is overkill. The vast majority of my use is very similar to yours, and my simple answer to why not a 150, I just don't like 150's (except the Raptor). Zero interest in owning an F-150, but I did want a full size truck and was always attracted to the Super Duty.
Old Jul 7, 2024 | 01:16 PM
shawnee1's Avatar
shawnee1
A good deal and fun to drive. You can't beat that.
Old Jul 7, 2024 | 01:32 PM
rna352's Avatar
rna352
Hello all,
You don't need forscan to lower psi for ride comfort any more than you need an annoying chime to buckle your seatbelt. It's just a light on the dash among many.
On my short wheelbase Super Duty on 285/18's I usually run around 54F/50R cold. Ride quality is still terrible, relatively speaking, but it's better.
When I plow snow I run max pressure on the fronts, and when I haul over 10K I run max pressure on the rears. I try and keep it simple and not overthink it.
You can't honestly be concerned about the cost of fuel and tires if you buy a Super Duty to haul luggage (not that theres anything wrong with that).
Old Jul 7, 2024 | 02:37 PM
RandyinTN's Avatar
RandyinTN
The tpms light on the dash is small and in out of the way spot. You will rarely notice the light except at start up. I run 45-50 in the back and 55 in front when mostly empty
Old Jul 7, 2024 | 03:35 PM
nc350's Avatar
nc350
Bought a f350 bc you could....you sir are indeed a red blooded American!
I have a '22 f350 ccsb and I run the stated pressures on the door placard. I'm usually towing our 5th wheel so I absolutely want the proper inflation when loaded. When I hang it up for the winter and hunting season is in, I lower the rears to 60psi as well. It helps a little.
At the end of the day, it's a HD truck, its not gonna ride like a Volvo suv or something.
Old Jul 7, 2024 | 06:33 PM
Harry24's Avatar
Harry24
Trailering
We had Expeditions and in 2018 we traded in our Expy for an 18 F250 King Ranch ccsrw 6.7 Diesel. Truck was great but we"talked ourselves into thinking it's overkill", which it was but ran great and pretty smooth. We went back to an Expy and slowly realized how much we missed the Superduty. So here we are, back in the Superduty family and loving it. Just trying to make the ride a bit smoother. I know there is no real way to get good mileage or a great ride.
Old Jul 7, 2024 | 07:37 PM
morehouse7's Avatar
morehouse7
He wanted a truck....
Old Jul 8, 2024 | 10:22 AM
nitebreeze's Avatar
nitebreeze
I never had forscan and I have had the low tire pressure light illuminated on the truck dash for five years now and it still does not bother me. 56/40 psi unloaded on 35x18. Rides great.
Old Jul 8, 2024 | 01:05 PM
WXboy's Avatar
WXboy
Same here, I run a target of 53 to 55 PSI and when I'm not towing the tires still wear in the center faster than the outside. I could probably drop down into the 40s for the best wear and ride quality, but I hate looking at the TPMS warnings.
I imagine that 75 to 80 PSI in one of these trucks would be akin to a pogo stick or a mechanical bull.
Old Jul 9, 2024 | 10:20 AM
rufushusky's Avatar
rufushusky
Honestly, I have been tooling around with 80psi (cold) in my Falkens and I haven't noticed much of a difference from the 65psi I was running before. I pumped them up when I picked up our fifth wheel and haven't felt the need to bring them back down. Given the context it is a 3/4 ton truck it isn't going to ride like your grand father's caddy, I think it is pretty good. My father has a set of x-code springs on the front end of his 2000 F350 back in the day... hitting a pot hole on those would rattle your fillings. It was an awful ride when the plow wasn't on the front end. Of course it is all subjective.
jdadamsjr
6.7L Power Stroke Diesel
Apr 26, 2012 11:09 AM
peachboy
Jun 18, 2009 11:28 PM
SteelHorse08
2004 - 2008 F150
15
Mar 26, 2008 09:31 AM
ascheperle
Dec 27, 2005 08:24 AM
