FYI -Tire Load Ratings for Michelin LT275/65R20
Old 04-24-2012, 03:44 PM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
Trying to balance load handling with ride quality, so I called michelin and with MY tire and MY F-250 this is what they said - YRMV
PSI Load
55 2850
60 3030
65 3195
70 3375
75 3540
80 3750
obviously will err on the side of more than enough, but why ride on rocks unless you have to
so instead of blindly putting 80 psi all around to go to max rating, I could run 55 front and 70 rear and be very safe with tire loads for my gcwr and 5er !!! - cool !
Old 04-24-2012, 11:40 PM
caere's Avatar
caere
caere is offline
I have the same tires and the door sticker says 65 psi front and back. Not sure where you got the 80psi from. It may be on the tire but that's not vehicle specific.
Old 04-25-2012, 06:33 AM
seanjackmc's Avatar
seanjackmc
seanjackmc is offline
My 2011 350 says 65/80
Old 04-26-2012, 07:36 AM
jdadamsjr's Avatar
jdadamsjr
80 psi i sthe pressure at which it will handle the 3750 per tire l
the tire placard on the truck tells u what ford suggest aas an unloaded air pressure
i found with my heavy pin wgt that it was a lil too soft and squirmed a bit
so went up to 75 and it was much better ride
AND maybe just a coincedence but my mpg went up after !
Old 04-26-2012, 11:09 AM
SouthernCamper74's Avatar
SouthernCamper74
SouthernCamper74 is offline
Very interesting nice thread!
cory5517
13
11-13-2013 01:57 PM
BolognaBlake
1999 to 2016 Super Duty
04-19-2011 03:22 PM
rb8484
04-01-2009 10:24 AM
toa5150medic
24
06-12-2007 09:41 PM
03f350crew
16
04-19-2004 10:00 AM
Quick Reply: FYI -Tire Load Ratings for Michelin LT275/65R20
