Solid front axle swap
Old Apr 18, 2014 | 03:24 PM
kidkyle21's Avatar
kidkyle21
I have a 1991 Ford F2 5.8 L 4 x 4
What exactly does a axle swap entail and how is it different from when I have already
Old Apr 18, 2014 | 03:30 PM
Fordman96's Avatar
Fordman96
What you currently have is a TTB front axle which allows each wheel on the front to flex individually. If you swap to a solid axle, when one when goes into a hole the front axle flex's in a different way. It compresses the suspension on the opposite side of the truck in the front.
https://www.ford-trucks.com/forums/1...swap-info.html contains some information.
And fullsizebronco.com has a whole forum dedicated to solid axle swaps.
Solid Axle Swaps - FSB Forums
Old Apr 18, 2014 | 03:54 PM
kidkyle21's Avatar
kidkyle21
if i was doing a 6" lift i was told that a swap would be a good idea but i personally dont like that idea
Old Apr 18, 2014 | 04:10 PM
Jarryd's Avatar
Jarryd
Why not? Solid axle rides better, is more durable, looks better, won't eat ball joints, it's a win in every direction.
Old Apr 18, 2014 | 04:17 PM
kidkyle21's Avatar
kidkyle21
how does it ride better i always though independent suspention was the way to go
Old Apr 18, 2014 | 04:19 PM
Jarryd's Avatar
Jarryd
TTB binds up a lot.
Old Apr 18, 2014 | 04:44 PM
kidkyle21's Avatar
kidkyle21
what do u mean sorry if im annoying just looking to educate myslef
Old Apr 18, 2014 | 04:47 PM
Fordman96's Avatar
Fordman96
The angle of a TTB can cause binding if you make it "flex" too much while you are off roading since the axle flexes in the middle and on the spindles. I straight axle only has flex on the spindles/ball joints and the whole axle moves.
Simple terms, less moving parts to break.
Old Apr 18, 2014 | 04:52 PM
kidkyle21's Avatar
kidkyle21
awh ok that makes sense thanks so now that i under stand that what would u recomend as a swap
Old Apr 18, 2014 | 05:49 PM
rla2005's Avatar
rla2005
Swap in a Dana 60 from a F350.
Old Apr 18, 2014 | 05:53 PM
Jarryd's Avatar
Jarryd
The cheaper swap is a dana 44 from a 78-79 f100 or bronco. That's the route I'd probably go because it's setup for coils not leaves.
Old Apr 18, 2014 | 05:58 PM
rla2005's Avatar
rla2005
The OP has a 4x4 F250, it already has leaf springs. Plus it already has 8 lugs.....
Old Apr 18, 2014 | 05:59 PM
Jarryd's Avatar
Jarryd
Didn't catch that. Yea do the dana 60.
Old Apr 18, 2014 | 06:07 PM
rla2005's Avatar
rla2005
I had to look twice myself!
Old Apr 18, 2014 | 06:10 PM
garthneddy's Avatar
garthneddy
I always get a kick out of all the misinformation thrown around when this subject comes up.
