Sponsored by: Auxito
Most likely problem
Old Jul 5, 2024 | 08:11 AM
toucan00's Avatar
toucan00
4wd High
Most likely problem
After some intake work and a couple of starts - my truck shut down (2002, 4.6l) I can turn the engine by hand 10-20 degrees, either way, then it stops. plugs are out.
Any suggestions? When it stopped - no loud noises, no steam, no smoke.
Old Jul 5, 2024 | 09:57 AM
Jon Freeman's Avatar
Jon Freeman
Drain the oil, remove oil pan and look up into engine to see if anything is visibly broken (?)
Old Jul 5, 2024 | 11:50 AM
BareBonesXL's Avatar
BareBonesXL
https://www.ford-trucks.com/forums/1...rustrated.html
Old Jul 6, 2024 | 06:03 AM
manicmechanic007's Avatar
manicmechanic007
Motor work sucks!
Sounds like something broke
I would marry a stethoscope for a few days and get a good assistant
Have your assistant marry a stethoscope too, and you can switch off turning the crank and listening
Don't switch stethoscopes, each of you get your own
ClayMcCoy68
94
Nov 28, 2020 08:34 PM
NICK_1421
6.4L Power Stroke Diesel
Feb 27, 2015 06:31 PM
77 2wd
Dec 5, 2012 09:41 PM
brickyiowa
Jun 22, 2012 10:28 PM
Butch(OH)
May 23, 2007 08:28 AM
