2001 E350 r4100 has no reverse.
Old Jul 5, 2024 | 05:39 AM
3oldshuttlebusses's Avatar
3oldshuttlebusses
1st Gear
Good morning and trying to figure out why one of the three shuttle buses has no reverse.
2001 E350 r4100. Have the pressure gauge hooked up and nothing in reverse. And very curious about wiring conditions at neutral switch
Old Jul 5, 2024 | 08:37 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Nothing electrical can cause no reverse in a 4R100 transmission. The only way a 4R100 transmission won't have reverse is if something mechanical has failed inside the transmission.
I have heard of the feedbolts loosening and that causes a big pressure leak internal to the trans. It's longshot, but possible. Drop the pan and the main valve body to access these bolts.
I think it is more likely that you've had a clutch failure that is dumping all of the pressure in reverse.
Old Jul 5, 2024 | 10:51 AM
tabijan's Avatar
tabijan
Tangent topic
@Mark Kovalsky , do modern transmissions have reverse wear failure from one moment to the next? I’m thinking of older transmissions that take longer and longer for reverse to engage as a sign the reverse clutch(?) is worn.
Sixto
07 E350 5.4 198K miles
Old Jul 5, 2024 | 01:56 PM
Mark Kovalsky
Wear usually will make the engagement take longer and longer until total failure.
Aww
Dec 27, 2023 12:08 PM
asterof
1997 - 2003 F150
Nov 12, 2023 02:50 PM
blue76
1997 - 2003 F150
Aug 21, 2019 11:52 AM
Rockafella
Feb 15, 2003 09:09 PM
