Sponsored by: Real Truck
No reverse
Old Dec 26, 2023 | 09:38 PM
Aww's Avatar
Aww
3rd Gear
No reverse
2001 f250, 7.3l
today I went into store, when i came out started truck it would not go into reverse, when in reverse truck moves forward, when in park seems to want to go forward too, like under a load when u rev it up. When driving it does not shift right since this problem of no reverse started.
Old Dec 26, 2023 | 10:08 PM
JoshHefnerX's Avatar
JoshHefnerX
Start w/ a fluid check and make sure the linkage is all moving as it should..
Thought on one of the rebuild vids I'd watched it said 3rd and reverse engage at the same time and reverse is weak in the clutch packs... May be one isnt engaging if that's true.
Old Dec 26, 2023 | 10:11 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The forward clutch is stuck on. Usually, that's because the forward clutch is burnt, and the heat welded it together. I think it's rebuild or replace time for your transmission.
Old Dec 26, 2023 | 11:03 PM
JoshHefnerX
The master has spoken.
Old Dec 27, 2023 | 05:36 AM
Aww's Avatar
Aww
3rd Gear
I forgot to add in my frustration, had tranny rebuilt about 3 years ago, dont drive the truck that much so less then 4000 miles on it
Old Dec 27, 2023 | 12:08 PM
redford's Avatar
redford
FTE Leadership Emeritus
Sounds like it wasn't a very good rebuild.
asterof
1997 - 2003 F150
Nov 12, 2023 02:50 PM
Frank79
Jun 18, 2021 05:40 PM
Patina65
May 16, 2021 06:53 PM
evan1242
Aug 7, 2015 02:43 PM
Rockafella
Feb 15, 2003 09:09 PM
