Sponsored by: Auxito
2001 reverse shudder
Old Aug 18, 2019 | 12:10 PM
blue76's Avatar
blue76
2001 f150 supercrew 5.4. I get a bad shudder when i go in reverse. Forward gears seem fine. Just reverse. I've changed fluid, didnt make a diference. I dont get any codes. drives great except for reverse. Any ideas?
Old Aug 19, 2019 | 06:14 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Is it just while engaging Reverse or is it while moving?
Any particular condition for this, like backing uphill or down?
How many miles on the transmission?
Old Aug 20, 2019 | 08:09 AM
blue76's Avatar
blue76
just while moving. it goes into gear fine. 124k miles. seems like the more load is placed on it the harder the shudder.
Old Aug 20, 2019 | 04:24 PM
Bluegrass 7's Avatar
Bluegrass 7
Reverse is a mechanical operation, no shift solenoids involved.
The internal linkage involved may have come apart.
Only way to tell is drop the pan and look it over but know how it's supposed to be.
There is a case pin involved, so look that over as well.
If all forward operations are ok, I think you will fine the problem with the reverse hardware or it's adjustment.
Good luck.
Old Aug 21, 2019 | 11:52 AM
blue76's Avatar
blue76
Thanks for the tip!
jle70
Oct 10, 2015 10:47 AM
036.0stroke
Oct 19, 2012 11:44 PM
Country705
Feb 25, 2007 07:23 PM
Rockafella
Feb 15, 2003 09:09 PM
