Power brake Vacuum pump
Old Jul 1, 2024 | 05:16 PM
Mr.Jaja's Avatar
Mr.Jaja
8th Gear
Angry Power brake Vacuum pump
Here I have a new problem.
After getting the truck running again, Fuel related issue, the power brake failed on my last Saturday. I drove it home with standing on the brake when needed. I have replace the Vacuum pump 3 time in the last 6-8 K miles. (yes, around 2K and they fail) I use Auto-zone, but like to get one made in US if possible with should last 10 years again. Any recommendation before I go to AZ again.
Old Jul 1, 2024 | 07:09 PM
96SD's Avatar
96SD
I'm sorry I can't help you but I can bet before too long we will all be running hydroboost.
Old Jul 1, 2024 | 07:26 PM
96XLTczny's Avatar
96XLTczny
I seem to recall reading that vacuum leaks can kill the pumps prematurely.
Some "light" reading. Ha ha ha.
https://www.ford-trucks.com/forums/1...ming-on-2.html
https://www.ford-trucks.com/forums/1...ing-signs.html
Old Jul 1, 2024 | 08:53 PM
Mr.Jaja's Avatar
Mr.Jaja
8th Gear
Looks like a STANDARD failure on this Trucks. What is the advantage of the dual tensioner?
Old Jul 1, 2024 | 09:00 PM
96SD's Avatar
96SD
The single wheel tensioner can start to deflect causing belt issues.
Old Jul 2, 2024 | 08:55 AM
knottyrope's Avatar
knottyrope
white tubing near the hinge on passenger side rots out and allows in extra air/moisture/oil which kills the carbon vanes
Old Jul 2, 2024 | 09:09 AM
z31freakify's Avatar
z31freakify
You could add a super duty electronic vacuum pump, you will also need a vacuum canister from a super duty. I wouldn't know how to wire it to shut of a certain vacuum pressure though.
Old Jul 2, 2024 | 09:42 AM
96XLTczny's Avatar
96XLTczny
Or a brake vacuum pump, diaphragm or vane type with built-in vacuum switch, from Summit.
Leeds, CVR, Summit brands are listed here:.
https://www.summitracing.com/search?...0vacuum%20pump
Then do the oem vacuum pump delete/dual idler mod.
May do the smaller vacuum pump for accessories later when I have the money. Already have the hydroboost going on.
Old Jul 2, 2024 | 01:34 PM
knottyrope's Avatar
knottyrope
I read that it does not have enough volume for stop and go traffic, the SD used it only for HVAC controls
Old Jul 2, 2024 | 02:57 PM
97-psd's Avatar
97-psd
X2 on looking for vacuum leaks. You could be pulling debris and moisture into the system which is causing the failures.
Old Jul 2, 2024 | 03:13 PM
z31freakify
I forgot SD's have no vacuum brake booster, so this might not work on our old trucks
Old Jul 8, 2024 | 09:52 AM
96XLTczny's Avatar
96XLTczny
pbs_girls on fleabay have Delphi vacuum pumps as well as the hydroboost pushrod kits.
Item # 223485994760
kyle j
Apr 23, 2016 05:44 AM
U D-SIDE
Apr 10, 2010 10:05 PM
Vinford
Sep 13, 2008 09:01 PM
potsiewebber
Nov 23, 2007 09:31 PM
smashing4455
13
Aug 11, 2005 05:42 PM
