Just picked up a van that needs a new engine. Just wanted to confirm that a 4.6 from an 08 crown vic would swap over directly, and if not, which parts would need to be swapped over. Thanks!
You will be in the same boat with the new engine if it's the PATS problem.
Sorry, been a few updates since I last posted. Was waiting on wiring diagrams for a bit.
Figured out it was originally a fleet vehicle, so no PATS and there was nothing flashing on the dash anyways for anti theft. Dug a little deeper and found spark, but no injector pulse. Eventually found a blown fuse and now have injector pulse showing on the noid light. Still no start though, so I started checking compression and it was all over the place. I think it must have jumped timing, maybe lack of maintenance?
I found a cheap, strong runner near me, so I’m thinking I’ll go that route at this point.
