70 E300 steering questions.
Old Sep 13, 2022 | 05:33 AM
E300's Avatar
E300
Trailering
Hello, I am new here and looking for information on my 1970 E300. The steering bell crank is washed out and needs to be worked. I need a starting point for parts. Do you have numbers?
Old Sep 14, 2022 | 07:52 AM
manicmechanic007's Avatar
manicmechanic007
You might find a number but I doubt you'll ever find a new part to buy
The bushing might still be available
Make a 4x4 out of it with leaf springs and a rack or steering gear?
Good luck
Old Sep 14, 2022 | 08:17 AM
tabijan's Avatar
tabijan
What does “washed out” mean?
Sixto
07 E350 5.4 183K miles
Old Sep 14, 2022 | 04:10 PM
E300's Avatar
E300
Trailering
This is the monster I am after
Old Sep 14, 2022 | 09:03 PM
manicmechanic007
To put it lightly
You are screwed
Old Sep 15, 2022 | 03:21 AM
E300's Avatar
E300
Trailering
I am very tenacious, and I will figure it out, the van is in such good shape I cannot put her down. There is always a solution.
This is the way it came out of the bush
Old Sep 15, 2022 | 04:32 AM
E300's Avatar
E300
Trailering
The factory door seals are still mint along with the door bottoms. All the flanges are still green. The doors close like factory. 41,000 original miles. glass is mint.
Floor is mint, seats are like brand new
Just a little rust to repair
Old Sep 15, 2022 | 06:46 AM
manicmechanic007
I agree
It is not worth junking it yet
But, you are never going to find that bell crank new or rebuilt
So it might be time for leaf springs and 4x4, the whole shootin match as far as steering goes
It's too bad someone like Moog never made a aftermarket replacement part (there just aren't enough of those vans out there)
Old Sep 16, 2022 | 04:19 AM
JWA's Avatar
JWA
Beauty is in the eye of the beholder, "mint" and "like brand new" this van and some of its components are NOT.
As a former body shop owner I see significant rust already formed along pinch weld and wheel well areas too. If that's not expertly addressed and repair it will advance quite quickly.
Old Sep 16, 2022 | 04:36 AM
E300's Avatar
E300
Trailering
For 52 years old, I consider it mint. The structure is awesome. I have been a body man for 40 years and I have fabricated all of the replacement rockers and lower 1/4s. I will post pics of the progress, and yes I have an 8' break, bead roller, English wheel. As far as the steering components, I will remove and work it on the bench/ machine shop to make it right. There seems to be a shortage of tec information on these steering systems. Not for long though, I will plow through it, as body men do when challenged.
Old Sep 16, 2022 | 08:12 AM
manicmechanic007
Something to think about for your fng bell crank
Jaguar ball joints in the older XJs had shims in them and the ball itself was the size of a golf ball and came out
You could remove a shim and make a loose ball joint tight again
You, if you knew the big guy JC, you might be able to have a machinist cut your original one to where a jag setup can be modified to work in yours
If you were to prefect that procedure you could sell about three thousand units maybe
Old Sep 16, 2022 | 01:07 PM
annaleigh's Avatar
annaleigh
1969 and up with manual steering E300
Steering bell crank part number C8UZ-3355-B
1971 and up with power steering E300
Steering bell crank part number D1UZ-3355-B
1969 and up with manual steering E100-E200
Steering bell crank part number C8UZ-3355-A
Old Sep 18, 2022 | 05:08 AM
E300's Avatar
E300
Trailering
You nailed it, I typed it in and there it was. Section 32 - '64-'72 Ford Trucks Master Parts Catalog - FORDification.com
Starting point, now to find parts. Thanks very much
Old Sep 19, 2022 | 12:35 PM
annaleigh's Avatar
annaleigh
so you need the 1969 and up with manual steering E300
Steering bell crank part number "C8UZ-3355-B"?
I am sure there is a good one around the world somewhere, but where? I have tried a couple of sources I use such as rear counter, green sales, and NOS but with no luck so far.
You may wind up needing a fabrication shop to help out.
Keep us informed and let us know of any good links you come across for old parts.
Old Sep 20, 2022 | 08:17 AM
manicmechanic007
Did you try contacting stillwellsobsolete om ebay who had one for sale recently?
He has an absolute ton of sheit
It was ebay item number 122731311675
I googled a 3355C and found that B for sale
