Tail gate stuck closed what to do?
Old Jun 30, 2024 | 12:25 AM
Venomv8's Avatar
Venomv8
Ive been racking my brain and I cannot think of way to get this tail gate opened without ruining it. Backstory- I bought a recently painted bed for my project truck that was professionally done, paint and body looks great which is why Im trying to figure out a way to get this remedied without ruining paint or metal on gate.
The issue- the previous owner installed the latches, with no rods attached to them, then decided it would be a good idea to close the tail gate to check gaps on bed. Tail gate latched and there are no rods attached to unlatch it. So anyone have any tricks to unlatch them without cutting out metal to access the latch? Ive tried putting small plastic pry sticks but there is just nothing to contact and release them that I can see. Thanks in advance!
Old Jun 30, 2024 | 04:19 AM
Crop Duster's Avatar
Crop Duster
That was a senior moment. Those latch screws are #4 Phillips but you might be able to pry the tailgate to one side far enough to get a #3 Phillips in there to remove the screws.
On my #3 and #4 Phillips screwdrivers I tach weld a nut on them near the handle that way you can push with one hand and turn it with a wrench to keep the screwdriver from camming out and ruining the screw.
Old Jun 30, 2024 | 09:00 AM
Crop Duster
I might need to clarify what I meant. I'm referring to the part of the latch that is screwed to the bed not the tailgate itself.
Old Jun 30, 2024 | 09:34 AM
Venomv8's Avatar
Venomv8
Id agree with the senior moment but the previous owner was a 20 year old kid that was trying to do it as a project before be lost interest haha. Really good kid though just had a lapse in thought for a moment. Im guessing youre referring to the portion where the tail light resides in your post and trying to unbolt the latch? I can look again but They had the gaps pretty tight, Im not sure if I have more than 1/4" on each side of the tail gate, but Ill give it a look
Old Jun 30, 2024 | 10:28 AM
TA455HO's Avatar
TA455HO
Lead Gopher
I used one of the rods backwards and passed it through the center handle opening and after many tries I was able to hook the 90 degree bend of the rod into the end of the latch and pull. It definitely will move the catch some. Hook a flexible but fairly strong piece of wire to the rod so if you drop it you can fish it back out.
Old Jun 30, 2024 | 04:04 PM
Tom H So. Ca.'s Avatar
Tom H So. Ca.
I like the hook idea of TA455HO!
This is kinda a last resort way that might work.
You may be able to access the latches between the gate and the bed with a screwdriver or two and try to push in the latch and get one side out and then the other. An additional item may help. Delivery trucks use a ratcheting wedging bar from one side of the truck to the other to hold things in place, I think they are also made for pick up trucks. Maybe someone you know has one to borrow. Wedge the bed apart CAREFULLY right at the tail gate only enough to use the screwdrivers. If the bed stays spread a bit when done, a come along or ratchet strap may pull it back together.
Good luck!!
Tom
Old Jun 30, 2024 | 05:53 PM
Venomv8's Avatar
Venomv8
I was wondering if that would work and Id be able to fish something into the latch to pull. Definitely will give that a try, if it takes me hours Id rather do that than cut holes theough the good paint and metal.
Old Jun 30, 2024 | 05:55 PM
AZSCAWPION's Avatar
AZSCAWPION
All good ideas but don't over think it. Push in a 1" putty knife from the inside to release the latch. So easy even a caveman can do it.
Old Jun 30, 2024 | 05:59 PM
Venomv8's Avatar
Venomv8
what year do you have? I can look through on mine and that pillar behind your putty knife is blocking the latch on mine it seems. I cant even see the latch through that gap. Ill give it a try but not sure I can access the latch
Old Jun 30, 2024 | 06:10 PM
AZSCAWPION's Avatar
AZSCAWPION
You don't need to see it. But it will take a bit of force.
***edit
A 1-1/2" or wider putty knife works even better as it is less likely to get hitched up on the catch plate.
mytoolman
Feb 28, 2024 01:00 PM
2 stroke man
Aug 8, 2008 03:33 PM
1978fordf250
May 18, 2005 10:42 PM
Huntsman
19
Sep 10, 2004 06:46 PM
4x4x4x4
Mar 28, 2002 10:03 PM
