Keep c4 or go c6
Old Jun 23, 2024 | 12:25 PM
Monkey shooter's Avatar
Monkey shooter
4wd Low
Keep c4 or go c6
1966 f100, has 91 model 302 and c4 trans. C4 leaks horrible, I have a c6 from a 85 f150, can I make this work fairly easy? Thanks for the help
Old Jun 23, 2024 | 12:37 PM
Crop Duster's Avatar
Crop Duster
Your best option is to rebuild the C4 if it is in there and working. The C6 isn't the best choice for a 302 since they are big heavy-duty transmissions and take away a lot of HP. Also, the C6 will not go in from the bottom without removing the center crossmember and unless your truck originally had an auto it will be riveted in.
What type of shift linkage do you have now? Also, what kickdown linkage do you have?
davewave649
Feb 5, 2011 07:54 PM
kmacht
Aug 13, 2009 07:54 PM
BlackLabel78
Jun 1, 2009 12:30 AM
Out_Sider
Sep 26, 2004 02:00 AM
MKPJ1
Jul 1, 2002 08:07 PM
