Air conditioning loses power under strain
Old Jun 18, 2024 | 07:25 PM
88f150rwd's Avatar
88f150rwd
7th Gear
Old Jun 18, 2024 | 08:34 PM
Conanski's Avatar
Conanski
Originally Posted by 88f150rwd
When under strain, like going up a hill or accelerating, the AC will weaken and stop coming out of the main vents;
Sounds more like a vacuum problem, if the airflow fades to defrost under load then the diverter door which is vacuum powered is losing vacuum. Prime suspect parts are under the hood though, they include the vacuum resovoir(juice can on the passenger inner fender, rigid plastic vacuum lines particularly the white one that goes into the firewall near the blower motor, and any check valves(round black plastic disk) in the lines
Old Jun 18, 2024 | 09:11 PM
MountainManRobb's Avatar
MountainManRobb
It does sound like you have a vacuum problem. An EGR valve that is sticking open can act like a vacuum leak, causing vacuum leak-esque problems. You need to check the vacuum check valve in line on the vacuum line feeding the hvac system.
Old Jun 18, 2024 | 10:14 PM
88f150rwd's Avatar
88f150rwd
7th Gear
Old Jun 19, 2024 | 07:13 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Why would you ask for help and then delete all
your comments?
Zookie400
Connecticut Chapter
888
Aug 1, 2012 02:23 PM
johntollakc
Oct 21, 2011 09:14 PM
4.go
1983 - 2012 Ranger & B-Series
Aug 8, 2009 09:56 AM
big 390
2004 - 2008 F150
May 20, 2008 07:15 PM
reac
16
Sep 13, 2003 11:49 PM
