GM vs Ford
Old Jun 17, 2024 | 04:56 PM
  #31
twobelugas's Avatar
twobelugas
Originally Posted by Montesa
There's no cylinder deactivation on the Cummins. On the Hemi, unlike the GM engines, it's now mostly due to not changing oil. I had dozens of Hemi service trucks many with 200k+ and never replaced any lifters. The once excellent GMs were very troublesome when they went to the DFM system.
Luckily for GM they didn't use displacement on demand for the 6.6 L8T. By all accounts it is a better motor than the 6.4 Hemi, and two people I know with the GM L8T trucks, they tow up to about 12-13k across the Sierra Nevada passes with no complaints and nothing bad to mention from the direct injection.
Old Jun 17, 2024 | 04:59 PM
  #32
ShotgunZ71's Avatar
ShotgunZ71
Very true. We had a 2010 Yukon that was a great vehicle. We were on a trip, I got the "Engine Oil Low, Add 1 Quart" message. Stopped at a local Walmart and added a quart. Once we got home, I went online and ordered a new ECM that had the 8-to-4 eliminated. Changed that out and it ran great for the next few years without using oil. Even with the new setup, they're still not near as reliable as the older V8s. I still have an original 5.3 in my 1999 and have had many offers for the truck. Many like the fact it has the first series 5.3 engine. Same can be said for the old 302 and 351 in the Fords. They were dang near bulletproof, too.
Old Jun 17, 2024 | 05:00 PM
  #33
twobelugas's Avatar
twobelugas
Originally Posted by Rwhjr
lol so dodges don’t have issues according to big *****?
I have some in a fleet and feel otherwise
I had a 2017 Ram for a bit when I was between Fords, the rook leaked like crazy to the point where water would run out of overhead console like a water fall after sitting in rain for a day or so pointed up hill. Tried the rear CHMSL gasket, and checked all around the windows, looked the windshield was gonna have to come off to further diagnose. I sold it when 2020 hit and work dried up when CA shut down a lot of businesses for reasons.
I also didn't care for its rough ride, numb steering, and the rattling of interior parts. The 5.7 Hemi without the MDS was a fun motor to flog though.
Old Jun 17, 2024 | 05:19 PM
  #34
Split rims's Avatar
Split rims
I love my 2013 f 250 6.2.
If I had to replace it, I would go GM
in a heartbeat.
Old Jun 17, 2024 | 05:41 PM
  #35
B-ManFX4's Avatar
B-ManFX4
Originally Posted by willynilly
even if the cummins is still a bit less torq who really cares. the cabs dont fill with water. 4x4 always works. dw isnt a thing. and if the new trans is even half decent it will be better than fords 10spd clunskster
My cab doesn't fill with water. My 4x4 always works. My truck doesn't have a problem with death wobble. My trans isn't a 10 speed but it works awesome.
Every make has its faults. Question - if you hate Ford so much why are you here?
Just curious.
Old Jun 17, 2024 | 06:16 PM
  #36
twobelugas's Avatar
twobelugas
The pre-cyclinder deactivation 5.3 1/2 ton trucks and SUVs from GM up to 03 and pre-MDS 5.7 Hemi vehicles are going to be very sought after as time goes on. I'm not saying it will be as expensive as pre emissions diesels but people are going to realize the AFM/MDS/DFM/etc motors are just more temperamental as they age past the 10 year mark.
For anything short of heavy towing I tell people to also look at the much derided 2v modular F150s. They were some lazy SOBs compared to modern VVT motors, but they will run and run and run, slowly but steadily.
Old Jun 17, 2024 | 06:25 PM
  #37
jcb804's Avatar
jcb804
Originally Posted by Old and soft
Don't remember where I read it, somebody was trying to gather info to determine if cylinder deactivation was related to the mopar lifter failures.
To my knowledge the Hemi cylinder deactivation is on two middle cylinders on one bank and both end cylinders on the other bank. Yet on the Dodge and Ram forums there are reported lifter failures on any cylinder not just the MDS ones.
Old Jun 17, 2024 | 10:29 PM
  #38
willynilly's Avatar
willynilly
how do folks get past the mirrors. theyre awful
Old Jun 17, 2024 | 11:10 PM
  #39
FishOnOne's Avatar
FishOnOne
The same as Ford owners adjusted to the steps and that hideous front air dam.
Old Jun 18, 2024 | 05:57 AM
  #40
99powerstrokedF250's Avatar
99powerstrokedF250
As mentioned above, the Hemi failures aren't really related to the MDS. I personally believe it's a lack of maintenance, as most issues are. I put 110k on my '17 6.4 and had no issues with the driveline, no cab rattles/squeaks, no leaks, nothing. Oil change with Mobil 1 every 5k, tire rotations every 10k, fluids checked every couple fill ups, used good quality gasoline, washed it every few weeks. It still looked brand new and I really only had issues with the parking sensors (snow/ice/salt would crack them and then they'd fault out), and the MAP sensor died with no code, even when unplugged.
If you take care of it, it'll take care of you. If you don't, well...the old saying goes, 'if you don't schedule maintenance for your equipment, it'll schedule it for you.'
Old Jun 18, 2024 | 07:40 AM
  #41
WXboy's Avatar
WXboy
Most of the 5.7 Hemi issues stem from the fact that the oil spec keeps getting thinner and thinner without any changes to the engine. Notice that the 6.4 Hemi engines that spec 40 weight oil have FAR fewer issues.
I dumped the 0W20 out of my last 5.7 Hemi and put 5W30 back in and my valvetrain tapping immediately and permanently disappeared.
Old Jun 18, 2024 | 11:17 AM
  #42
DPelletier's Avatar
DPelletier
People who think that any brand is immune to issues is in for a rude awakening. I've maintained a small fleet of Ford/GM/Dodge/Ram trucks for the past 35 years and I can tell you with certainty that any and all can and will break down and have problems eventually. I buy trucks with the features I like, the ones I get a better deal on and the dealer also plays a part in the decision making process.....I wouldn't buy any of the big three trucks over any other over some perceived superiority in reliability. Certainly there are some known weak links in all vehicles but overall, you may have problems or you may not - often it's luck of the draw. All you can do is maintain them properly and keep your fingers crossed.
2 cents,
Dave
Old Jun 18, 2024 | 08:17 PM
  #43
rough_rider's Avatar
rough_rider
I cannot speak for everyone, but I can speak for myself. I am in no way saying any brand is immune from problems, but it isn’t any secret that Ford has been on the struggle bus the last few years. They have lead all auto manufacturers in recalls and warranties the last two or three years. It doesn’t seem like they intend to give that spot up in 2024 either. So in general, some manufacturers are making better products than others.
Old Jun 18, 2024 | 10:01 PM
  #44
twobelugas's Avatar
twobelugas
the hectic three year refresh-six year major redesign cycle ensures they are perpetually trying to work out bugs before they have to retool and use new parts.
Old Jun 18, 2024 | 11:34 PM
  #45
B-ManFX4's Avatar
B-ManFX4
How many of those issues are Sync related and how many are actually mechanical in nature?
