Steering wheel off by 90 degrees
Old Jun 16, 2024 | 08:55 AM
Lawsonland's Avatar
Lawsonland
3rd Gear
My son just bought a 2005 f150xl 4.2l and the steering wheel is off by about 90 degrees. It drives straight and no pulling. I look underneath and see no obvious issues. They previous owner said they hit a curb. Looks like the shaft goes straight into the rack & pinion, can this be reset or have to replace
Old Jun 17, 2024 | 02:39 PM
G2IC_Wraith's Avatar
G2IC_Wraith
If you "center" the front wheels, is there an equal # of turns to lock on either side?
Without knowing anything else, I would think the steering shaft that connects to the top input shaft on the rack & pinion needs to be unbolted & reattached in the "center".
The previous owners may have just "slapped" things back together without checking the center.
Old Jun 17, 2024 | 04:31 PM
Lawsonland's Avatar
Lawsonland
3rd Gear
Left side has less turns until it locks
Old Jun 17, 2024 | 05:50 PM
G2IC_Wraith
Assuming nothing is bent badly, I am thinking you need to set the wheels straight then unbolt the 10mm bolt on the shaft mount.
Then turn the steering wheel straight & bolt the shaft back to the input.
Old Jun 17, 2024 | 05:56 PM
Lawsonland's Avatar
Lawsonland
3rd Gear
Thanks. I give it a try. As far as I can see nothing is bent or damaged
Its_Green
Apr 4, 2022 12:39 PM
Buicknick72
Jan 25, 2022 06:14 PM
Sycostang67
23
Jan 18, 2010 09:42 PM
cadriver
1983 - 2012 Ranger & B-Series
Jun 9, 2007 08:39 PM
