Small vacuum leak.
Old Jun 16, 2024 | 04:53 AM
Gsd129's Avatar
Gsd129
Trailering
Small vacuum leak.
Hello. I have a 95 f150 5.0 4x4. Had my AC reacharged and noticed when on highway it would cut to defrost at 1600 rpm. I noticed the white vacuum line under hood was cracked. I cut it back put on and I replaced every single vacuum line under hood with silicone upgraded to 96 vacuum reservoir. Removed smog pump and all those lines are removed and capped at there solineds to prevent check engine light. It's alot better but does it under heavy load around 2100 rpm. Do I need to start looking at lines under the dash? Thank you
Old Jun 16, 2024 | 05:17 AM
TobyB's Avatar
TobyB
I've had the vacuum switch itself start leaking like crazy...
They can pop apart, or lose a seal.
t
Old Jun 16, 2024 | 05:42 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Does the vacuum reservoir hold a vacuum?
Old Jun 16, 2024 | 05:52 AM
Gsd129's Avatar
Gsd129
Trailering
Yea it holds a vacuum. This design doesn't incorporate the reservoir for HVAC system. It's just for EGR,smog and cat fresh air. (I might actually plumb it in to it).I removed and capped everything except EGR. No leak. Old coffee can was not looking healthy. I see two black lines go in hvac by passenger side firewall. Do brake bleeder vacuum pumps work for testing vacuum leak? I tested manifold and throttle body no leak.
GavinL
Jul 26, 2021 09:38 AM
oldcoupe42
15
Jul 22, 2017 03:41 PM
Bananarama
Modular V10 (6.8l)
17
Oct 3, 2010 10:14 AM
lifted77f250
Feb 13, 2010 07:45 PM
90F250351
Sep 24, 2009 01:26 PM
