Door handle problem
Old Jun 13, 2024 | 10:13 PM
Eminem1111111111111's Avatar
Eminem1111111111111
Door handle problem
I have a 1994 f150, the drivers side door has always been a little off since I’ve owned the truck. It doesn’t release the door correctly like the passages side, you just have to yank it and shove the door for it to open. Didn’t really care about the problem until I broke my 2nd door handle replacement. As you can imagine, yanking a small piece of plastic hard multiple times a day isn’t very good for said door handle, I’m tired of just replacing the handle. What do y’all think the problem is?
Old Jun 13, 2024 | 10:47 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
It is the latch itself that the handle bolts to. Fixed both my 96's with new latches. The pin where it pivots gets worn and moves a different direction than what it should.
Old Jun 13, 2024 | 11:49 PM
Eminem1111111111111
So then a new latch should do the trick? I’ll start shopping, thanks
Old Jun 13, 2024 | 11:57 PM
seschenburg's Avatar
seschenburg
You'll need to pull the door panel to inspect the mechanism, so you might as well do that. You can then see what the real problem is. Could be the handle hinge pin has worn down, the sheet metal the hinge mounts to is cracking/broken, the cable is stretched, or whatever.
Replacement cables are available, but I found that the F250 of the same vintage uses a metal rod instead of the cable. I swapped mine with that and won't have to worry about the cable stretching or breaking ever.
I also had to make a bracket to strengthen the mounting point. That door sheet metal isn't really proper for so much leverage over so many years.
Old Jun 14, 2024 | 08:41 AM
My4Fordtrucks's Avatar
My4Fordtrucks
^this^
It is a known problem which is why you can buy a reinforcement bracket if you don’t want to make one. That is, if you find that the inner door shell is the problem.
Old Jun 14, 2024 | 08:55 AM
jashelton97's Avatar
jashelton97
Take a look at the striker bolt/bushing as well. I believe obssolutions sells brackets for the handle too
1998F250SC
1997 - 2003 F150
Oct 25, 2009 10:50 AM
neilc88
Aug 9, 2006 01:06 PM
Mcol
Nov 27, 2005 04:04 PM
