Door Latch
Old Nov 15, 2005 | 10:56 AM
Mcol's Avatar
Mcol
Door Latch
Got a question for you guys. On my 94.5 Powerstroke the drivers side door latch doesn't work on the inside. I was told that it could be adjusted but when I looked at it I couldn't find a way to fix the problem. Any of you had this problem and if so how did you fix it?
Old Nov 15, 2005 | 12:41 PM
l-m tech's Avatar
l-m tech
have had to replace a few for bad inside door handle and it comes with a cable.if i remomber right.
Old Nov 27, 2005 | 04:04 PM
shellshock's Avatar
shellshock
Dunno if it'll help but i had get some steel welded onto the actual door cause the handle tor through the thin metal of the door
