Cell Booster Antenna cord entry point
Old Jun 13, 2024 | 07:15 PM
DadZilla23's Avatar
DadZilla23
1st Gear
Hi, I'm new here. 2023 F350 XLT. I'm trying to figure out where I could run the antenna cord to get into the cab from a cell booster antenna that I am mounting on the bed?
I heard of a rubber grommet under the driver floor mat, but I was hoping for another location if there is a good options.
Thoughts appreciated.
Old Jun 13, 2024 | 07:41 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
There are rubber capped access points at the back of the cab and under the floor, just have to look for them.
Old Jun 14, 2024 | 09:41 AM
KCoulter's Avatar
KCoulter
There are vents behind the back seat...I've run an antenna wire thru there before
Old Jun 17, 2024 | 10:43 AM
Dolomite Titan's Avatar
Dolomite Titan
I ran a weboost cable into the cab through a black grommet in-between the back of the cab and the bed. You can fold down the rear seat backs and remove the covering. Above the vents, will be some grommet options. You can pull out a grommet, score it to get your cord through and then re-seat the grommet. I also ran a power wire to the seat back area and mounted the weboost module back there. very clean and hidden install.
Old Jun 17, 2024 | 03:03 PM
Patrick4451's Avatar
Patrick4451
Has anyone ever used a Rugged Radio Mag Mounting plate on their hood(near A pillar) for mounting their cellular antenna, instead of some sort of bracket by the A pillar?
AZFordLover
Jul 3, 2022 10:44 AM
J ballan
Feb 22, 2022 09:00 PM
Dennis Bergman
Jul 18, 2021 07:14 PM
GJCAT
Sep 29, 2020 09:29 AM
Jrobole
Jun 3, 2016 07:49 PM
