Good day everybody I’m adding power brakes to my 1970 F350 build and I need the bracket that goes between the brake booster and the firewall. Does anybody know where I could find one other than a junkyard? Thanks in advance
Ford listed them as front and rear for some reason. 1967/72 F350 the front bracket was part number C5TZ2031C. The rear bracket was part number C5TZ2031D. These also fit 65/72 F100/250 (4X2).
shows as having the C5TZ2031C in stock. But not the D. No other N.O.S. company has anything. Maybe buy it and use it to be able to Fab the other bracket?
Thanks for your help. Do they show pictures of the two brackets? All the pictures I can find make it look like one bracket
You'd have to call and ask them. But notice in the illustration that I posted Ford had two arrows pointing at the two brackets. Both basic part number 2031. In that illustration the brackets appear to be left and right or inner and outer. But Ford listed then as front and rear.
