most power for the dollar
Old Nov 27, 2003 | 12:24 AM
justin23's Avatar
justin23
i have a 89 f 350 7.3L i have recently bought for hopes of saving my once new 2000 f250 7.3L, from going on over the 200000 mile mark,....ya know shes just now getting broke in. Anyway to my question i have went through the collant system, bought the gear driven starter for more rpms, two new batteries, new glow plugs,glow plug relay switch,air filter,oil and filter, put an electric lift pump on it, well what i am saying is i am on of those guys that would rather just fix the **** before it tears up u know. i do know that i will never get the power from this engine as i do my 2000 but what i am wanting is some power improvments......filters,chips,propane,turbo,..... any and all feed back would be great if u have had good luck or bad let me know....i know i bought a hypertech for my 2000 and it helped it some .....anyways i did some searching for this but didnt find much for this year i am needing 89 so thanks in advance
justin
Old Nov 28, 2003 | 02:02 PM
Spectramac's Avatar
Spectramac
There is no computer for an 89, so no chips. You can't inject propane without a turbo, so there you are. Turbo is the only thing you can do to make it a new truck. Everything else you'll keep asking yourself, "did it made a difference"? Probably around 3 grand but worth it.
Old Nov 30, 2003 | 05:58 PM
nogo73's Avatar
nogo73
I have to disagree You can put propane on a N/A motor
ziggster did it here is his website
http://www.members.shaw.ca/k2pilot/P...20article.html
Old Nov 30, 2003 | 06:42 PM
fonefiddy's Avatar
fonefiddy
If your going for HP/$
LPG is your best bet. 50 HP for the money you'd spend, is cheap
Old Dec 1, 2003 | 07:13 PM
justin23's Avatar
justin23
lpg?
can lpg be put on this truck? didnt know and if u know it could about how much would it cost?
Old Dec 1, 2003 | 10:53 PM
Spectramac's Avatar
Spectramac
Well, I'd hardly call what he's done there as absolute proof you can do it, but more power to him. I only said what I said after reading it in a brochure for ATS's propane kit.
Old Dec 2, 2003 | 05:01 PM
fonefiddy's Avatar
fonefiddy
Well, you'll need a tank, prolly 2 regulators,a nozzle and some hoes
Old Dec 3, 2003 | 11:19 PM
Spectramac's Avatar
Spectramac
I looked up the ATS flyer for their LP kit. They're using boost pressure to signal the load on the engine. That triggers the propane, that way you get it when you really need it. I guess the throttle switch works too, just not as accurate.
smithm31
36
Feb 10, 2014 10:40 PM
powerstroker100
17
Sep 16, 2011 01:54 PM
AndersL
24
Oct 11, 2010 10:09 AM
big buckeye
Mar 25, 2009 07:01 PM
justinthompson10
15
Apr 4, 2007 04:27 PM
