Brake Proportioning valve
Old Jul 17, 2024 | 06:20 PM
KULTULZ's Avatar
KULTULZ
Arrow
Originally Posted by 1TonBasecamp
I’ve often wondered about that with several companies over the last 10 or 15 years.
I started seeing Ford numbers crop up on packages a while back. But I’ve noticed that at least some of them come from Dennis Carpenter or Scott Drake (LMC too?). Who I think do have things worked out with Ford.
If the resellers are sourcing their parts through one of these companies, or one like them, that might be how they get away with it.
The vendors you mention, comply with FORD AUTHORIZED REPRO.
Others will use a close FORD PN (and it takes experience to differentiate) but not exact to get away with it and is usually junk.
Old Jul 19, 2024 | 07:09 PM
w951wxj's Avatar
w951wxj
So got the PV done - picked up a new master cylinder, mine is a non-power brakes. I don't have the original as the truck didn't have one when I got it but found something that says 73-79, 2wd - you know all the right stuff. My problem is the push rod pin seems to be short for the pedal. its almost 7 inches to the middle of the bolt hole and every thing I can find says 7 inches is correct for this truck...I have to be missing something unless there is suppose to be some slop play in the pedal like it doesn't actually come all the way forward/up? Im assuming that the starting point for the pedal should be as far up as it can go, maybe its not and starts lower to the floor than I'm thinking
Old Jul 20, 2024 | 06:10 AM
KULTULZ's Avatar
KULTULZ
Arrow
Can you identify the pin you are describing from the attached ILL?
Old Jul 20, 2024 | 09:06 AM
w951wxj's Avatar
w951wxj
If the pedal doesn't or is not suppose to be as far up and toward driver and it should have some slack then I guess I'm okay - just assumed the pedal would have no play once its all installed (all the way depressed to all the way undepressed)
Old Jul 20, 2024 | 10:29 AM
KULTULZ's Avatar
KULTULZ
Arrow
If the MC is correct and a quality replacement part, the included push-rod length should be to OEM SPEC. There should be a very small amount of slack so as not to have the pedal assy (incl push-rod) beating the MC piston as it goes down the road (annoying rattling). If installed and there is pedal pressure on the push-rod, the brakes will be partially applied (and the pedal just resting on the push-rod will not overcome the tension of the MC internal return spring). I see no anti-rattle spring on the brake pedal assy. This where you need the WORKSHOP MANUAL for the vehicle.
There are adjustable push-rods available if the one that came with the MC is an incorrect length.
Old Jul 20, 2024 | 02:54 PM
1TonBasecamp's Avatar
1TonBasecamp
Does (edited from “doesn’t “) the shop manual specify a distance from the pedal to the floor? Or is that only for clutch adjustment?
Old Jul 21, 2024 | 01:48 AM
KULTULZ's Avatar
KULTULZ
I am sure it does but I don't have a copy.
Old Jul 21, 2024 | 03:53 AM
1TonBasecamp
I might actually have one. Finding it, however… Now that’s the question!
If I had more time, and if my office didn’t still look like it had just survived the ‘89 earthquake, I might actually be able to put my hands on it. 🙄
Then again, I also have a pretty extensive database on disk. Drilling down into it might take some time too.
I’ll see what I can do.
Now, if 77&79 Rich has his stuff handy…
Question to the OP in the meantime. When the brakes are applied fully, just how far off the floor is it?
How much pedal travel from first push, until it stops?
Old Jul 21, 2024 | 04:11 AM
1TonBasecamp
I forgot to mention one thing w951… With manual brakes, the push rod usually snaps in good and hard into the back of the master cylinder.
This means that once the rod is attached to the pedal arm, the brake pedal can’t actually pull up very far. Like almost none at all.
When you say, yours is free to move up, do you mean it’s actually pulling the rod out of the back of the master cylinder? If so, I don’t think this is a good thing.
in any scenario
I’ve certainly seen this even on original applications, where the little snap ring clip, thingy broke and allowed the pedal rod to float in the back of the piston. But it’s not correct, especially with a new master cylinder,
Some masters have a very shallow piston back, which is usually for power brakes. The manual brake master cylinder should have a very deep well in the back, where the pedal rod snaps into the master.
Did yours come fully assembled with the rod, or was the rod separate in the box?
Old Jul 23, 2024 | 06:43 AM
w951wxj's Avatar
w951wxj
@1TonBasecamp So the new MC came with a pin that had a circular like tension clamp towards the end - when you finally get it all depressed an in the MC, it does click into place. You can't easily pull out the push rod so that is good. The new MC came with a push rod that appears to match up in size to everything I can find that says - like 6 3/4 to 7 1/2. Center of bolt hole to tip is 7. I think everything is good, probably just my anxiety putting back together and safety and all that. My assumption was the pedal would have no play and be as far forward as it could go but with the push rod clipped into place and does not really slide around, pressure from the master cylinder I think it should go together fine, I hope to get to the whole thing tonight - bleed it out and make sure of no leaks and good pedal pressure...of course that is if I can move one of the hundred other things I got going on to some other night.
Old Jul 23, 2024 | 07:14 AM
KULTULZ's Avatar
KULTULZ
... thingy ???
Showing your feminine side?
There is a retainer clip and yes it has to be intact to properly locate and retain the push-rod in the MC piston. They are available for service.
FORD BASIC PN 2B224
Old Jul 24, 2024 | 07:21 AM
w951wxj's Avatar
w951wxj
Once you get the MC port size and PV valve port sized all correct, it goes together like a snap...haha. Did not get it all bled out but its together - we'll see. Minor win the big picture, good win for me - hate brakes and brake like stuff.
Old Jul 24, 2024 | 10:23 AM
  #28
KULTULZ's Avatar
KULTULZ
But look at what you learned.
Old Jul 28, 2024 | 05:36 PM
  #29
w951wxj's Avatar
w951wxj
Exactly - learned I hate brake lines...hahaha. Its all bled, holding pressure - pedal is good and NO LEAKS....wahoo!!!
Old Jul 28, 2024 | 11:10 PM
  #30
KULTULZ's Avatar
KULTULZ
Thumbs up
You learned and hopefully others learned.
Mikulh
Apr 4, 2024 09:41 AM
custom cabby
Oct 7, 2009 05:02 PM
tonpartain
May 18, 2006 02:23 PM
WillFordTruck
Nov 30, 2004 05:07 PM
Motoxman_117
Jan 12, 2003 09:13 PM
