Anyone know if the proportioning value used in a 1972 F250 7500 GVW front drum truck can be used with front disc brakes for the same truck? They have a different number of outlets (drum config has more, since one output line goes to each front brake versus disc brake which has one outlet that goes to the front that splits off a "valve" (bolted to the cross member above the I beams) to each wheel?
NOTE: by all appearances, the spindle used for this GVW (and 8100) are identical whether for drum or disc application.
I believe that the valve in question is for operating the indicator light that lets you know when one of the independent systems has failed. As long as you have all drums you don't really need a porportioning valve. At least on my '69 the only valve is down in the frame rail and just turns on a "brake" light down by the parking brake release.
I believe talisker is right. My 70 has what is called a differential valve that just senses different pressures and turns on the light if one side is low. Front disc brakes require the proportioning valve to send different pressures to the discs and the drums.
Disc brakes require a LOT more pressure. Drum brakes are almost self activeting once you engage them. Just look at the little electro magnet that runs electric treailer brakes.
Disc brakes require a constant pressure to keep them within a minimum distance of the rotor so they just glide on the rotor surface for many reasons. The Bendix type drum system works by having the front shoe (minor) hit the drum and in doing so pivots the bigger (rear) shoe against the drum. fwiw.
On a drum/drum truck if you install an adjustable proportioning valve you will be able to adjust (reduce) rear brake pressure. This will allow you to stop without having premature rear wheel lockup. The pressure adjustment should be difference between front/rear if your loaded vs empty. Carl.....o&o>.....
