brake conversion questions
Old May 16, 2006 | 04:08 PM
tonpartain's Avatar
tonpartain
Howdy,
Preliminary info: my truck is a '72 f100...donor truck is a '74 f100
Two questions:
1. Do I need to exchange my original brake booster for the one from the '74?
2. The proportioning valve from the '74 is rusted out...do I need to find another '74 valve or can I use one from a later model f100/150? The master cylinders changed between '74 and '75 and also between '76 and '77.
Old May 16, 2006 | 08:32 PM
idealtrucks's Avatar
idealtrucks
Don't know about the brake booster, but any proportioning valve will work, as long as its off of a truck. All it does is limit the amount of pressure applied to the rear to keep them from locking up.
Old May 17, 2006 | 05:22 AM
jowilker's Avatar
jowilker
Originally Posted by tonpartain
Howdy, Preliminary info: my truck is a '72 f100...donor truck is a '74 f100
Two questions:
My recommendation is to make a complete swap, keep an engineered system. The rears are the same on both trucks. If a part is bad replace it.
John
Old May 17, 2006 | 06:18 AM
banjopicker66's Avatar
banjopicker66
You didn't say if your '72 has disc or drum front brakes - I assume it has drums.
You MUST change the proportioning valve to a disc brake type if you change from drums to disc.
It is called a proportioning valve for a reason: it delivers more braking force to the front by proportioning it out, to give you more effective braking.
They can be had a boneyards easily enough.
Old May 17, 2006 | 11:35 AM
idealtrucks
If you can't find a proportioning valve, just use your original distribution block and put an adjustable valve on the line going to the rear.
Old May 18, 2006 | 05:04 AM
jowilker's Avatar
jowilker
I disagree, distribution blocks and porportioning valves are not the same animal. The discs require a different fluid/pressure ratio than the drum rears and trying to get around that, could put you squarely in a place that you didn't want to be.
John
Old May 18, 2006 | 02:23 PM
idealtrucks
All a proportioning valve does is send more fluid to the front and less to the back. It keeps the back drums from locking before the front discs do. If you just buy an inline aftermarket adjustable prop. valve and put in in the line to the rear, you are essentially doing the same thing, but are simply able to adjust it. Race applications use this all the time to get the bias that they want.
