E4OD issues BUT only when warm
Old Jun 6, 2024 | 09:01 AM
Racecar_Dave's Avatar
Racecar_Dave
Trailering
So my bronco has an interesting issue in that when the trucks transmission fluid is cool doesn't show up but when the fluid is hot I have issues with second gear.
When warm the truck leaves in second gear and will NOT shift to third till I reach 39-45mph indicated on my speedometer. If I slow down slightly it will stay in third gear but if i slow down too much it resumes 2nd gear and wont shift out till ive reached suffiecinet speed.
I have placed a bottle of transmission fix in and it seems to have helped although I've only driven it 50 miles. It currently has its radiator cooler bypassed and uses a 6 row tube and fin external cooler.
My thinking is if i keep the fluid cool i dont notice the problem.
BTW I have already replaced the solenoid pack inside the transmission. Although I guess it could've gone bad agaI'm.
Right now my solution is to put an electric fan on the aux cooler and if that helps then the next plan of action would be to reroute the windshield squirter to drip on the cooler.
im hoping you guys have some insight
Old Jun 6, 2024 | 12:20 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What codes are stored in the PCM?
Old Jun 7, 2024 | 04:38 PM
Racecar_Dave
Trailering
no clue its a 1995. Not sure how I would even check them.
Old Jun 7, 2024 | 09:36 PM
Mark Kovalsky
You can read codes this way: www.troublecodes.net/ford
Old Jun 8, 2024 | 05:51 AM
Hsgill6821's Avatar
Hsgill6821
Even if it is 1995 you can still check them as they have obd1 I believe. Get a obd1 scanner, I use my bluedriver on all my cars and it works
Evan_P
24
Nov 18, 2012 12:12 AM
18436572
Jun 20, 2012 08:41 PM
moondog
Mar 22, 2010 09:42 AM
blueice
1997 - 2003 F150
Mar 10, 2005 10:13 PM
Texan1983
Jan 24, 2004 01:06 PM
