P0171 lean
Old Jun 4, 2024 | 05:55 PM
Jesus=king's Avatar
Jesus=king
1st Gear
P0171 lean
Hello all. I'm new to the forum, so what's up.
my sons 05 f150 stx 4.2 is running a lean code on bank 1 and engine shutters and runs like crap. What I've done, injector on bank 1,plugs, wires, ignition coil,maf, egr valve, fuel pump, fuel regulator, fuel filter,. Did a smoke test, sprayed starter fluid and tried water, both while watching rpms. No cracks in plenum. Checked compression on cylinder 1, compression good. Also the long term fuel trim is super high 29.7 and all the others are highish also 02 sensor seems good, Checked it on scanner and its acting just as 02 sensor2 upstream, all voltage is similar. I'm lost and have zero clues at this point. Thanks.
Old Jun 14, 2024 | 11:37 AM
booba's Avatar
booba
4th Gear
Possible exhaust leak around cats.
Old Jun 14, 2024 | 09:51 PM
steve(ill)'s Avatar
steve(ill)
all the little 1/4 inch vacuum hoses are 20 years old.. If one is cracked it can suck air... Pull them off one at a time and check for flexibility.. I had two by the exhaust manifold that got HARD and CRACKED on a 5.4 at a bout 15 years old.
Old Jun 15, 2024 | 06:42 AM
techrep's Avatar
techrep
Check the foam seal around the air box, tends to rot away and also check the seal on the gas cap. If these are bot good do what was recommended above.
BLope
1997 - 2003 F150
20
Jun 5, 2021 08:28 PM
ZachManXLT
1997 - 2003 F150
Sep 12, 2019 07:56 AM
stuckstudent
1997 - 2003 F150
18
Jul 18, 2018 07:08 PM
revitup
1983 - 2012 Ranger & B-Series
Aug 23, 2017 01:14 PM
desertruck
30
Apr 8, 2016 07:57 AM
