Offroad & 4x4
Transfer case Problems
Old Nov 26, 2003 | 09:57 PM
fordmudrunner2020's Avatar
fordmudrunner2020
A friend of mine just bought a 89 f 150 extended cab short box 4x4 for $200 it is actually in pretty good shape and i'm kicking myself for not buying it. Anyway it has a 302 and the transfer case will not shift into 4 low no matter what, but it will shift into 4 high and no it is not the auto hubs because he doesn't have any. The 4 hi works fine but no hope to get it in 4 low. I crawled under to see what was wrong thought it might be a linkage problem but the linkage moved fine and wasn't jaming against anything. So I would like to hear what you guys have to say I have never seen this before.
Old Nov 26, 2003 | 10:13 PM
Txquadhunter24's Avatar
Txquadhunter24
A friend of mines 87 did this but it wouldn't go into 4hi, but it would 4lo. The cause of it was worn shift forks inside the case
Old Nov 26, 2003 | 10:36 PM
fordmudrunner2020
Hmm it may be shift forks but the lever jams it is probably something internal though, what is what I'm trying to find out.
Old Nov 28, 2003 | 12:01 AM
Txquadhunter24
Yes, i meant it's the internal shift forks. First signs of wear is they pop out of 4lo or 4hi then finnaly wear to the point they won't go into gears.
Forgot to add It's rebuild time for that BW case. the usual cause of the wear is they have a internal oil pump if shaves or gunk starts clogging up the screen it causes wear problems.
Old Nov 28, 2003 | 07:37 PM
Bigredgashawg's Avatar
Bigredgashawg
Try shutting the engine off in neutral and shifting it into 4lo i had to do this on my 86 until i got the t-case rebuilt
ShortBed'86
Sep 6, 2012 10:46 AM
turbo diesel fan
Jul 20, 2011 11:04 PM
Nh-fordSD
Dec 28, 2010 06:40 AM
DarylZ
Sep 6, 2004 04:35 PM
cicada
Sep 23, 2001 11:39 AM
