i also have a transfer case problem. i can shift it between 2 high and 4 high but cannot shift into neutral or 4 low in the cab. but if i get under the truck and play with the linkage i can manually move it into neutral and 4 low. any suggestions?
what truck and t-case?
there are two t-case shift patterns.
one is push down and pull back for neutral-low, the other is pull over to the driver side door and pull back
