4R75E Solenoid Testing
Old May 28, 2024 | 07:05 PM
8BA Ford's Avatar
8BA Ford
4wd High
So, I'm working on a 4R75E in an Expedition. Needs a solenoid. I know that much. I ordered a new one, but I used the wrong part number. Ended up with the older pre-2005 version with a different connector when I needed the newer style.
I'm going to pick it up from NAPA tomorrow.
while I have the pan off, I want to go ahead and test the other solenoids since they're easy to get to.
What's the test procedure? I have bench power supplies, scopes, multimeters, etc. I haven't done much work on automatic transmissions (luckily) and I'd rather not miss something and have to do this again. Wasn't very fun to work on.
Old May 30, 2024 | 07:06 PM
zzyzxpat's Avatar
zzyzxpat
Why do you think it needs a shift solenoid? Maybe it does, but I have built 100's of them and never seen a bad shift solenoid.What year is it?
Old May 30, 2024 | 11:43 PM
8BA Ford's Avatar
8BA Ford
4wd High
'05 with 250K miles on it. Delay shifting into first from neutral or second, zero other symptoms. Fluid is fine, not low, smells fine, pulled the pan and there was some metallic "sludge" on the magnet, but not very much and not enough for me to be concerned with. I'm guessing it's been 150K miles or more since its been serviced. I'm swapping the filter along with the solenoid.
The solenoid is supposed to be here tomorrow, so I'll pick that up and install it tomorrow afternoon. I'll update the thread after a test drive.
Old May 31, 2024 | 08:50 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Neither shift solenoid is used to shift from neutral to first gear. So how do you determine which non-failed solenoid to replace?
Old May 31, 2024 | 11:36 AM
meborder's Avatar
meborder
Aren’t failed accumulators far more common on these?
Old May 31, 2024 | 05:09 PM
8BA Ford's Avatar
8BA Ford
4wd High
It's two solenoids in one housing.
Thanks for the smartass comment. Really helpful.
Old May 31, 2024 | 05:14 PM
8BA Ford's Avatar
8BA Ford
4wd High
No clue. I was told to replace the shift solenoid, so I did. Didn't seem to make much of a difference.
I'm buying a replacement vehicle in a few weeks, so I'll just drop the transmission and rebuild it or replace it. Never have had the opportunity to rebuild one and it'd be a good vehicle to learn on since I have some other AODE type transmissions in some of the other vehicles.
Old May 31, 2024 | 05:43 PM
Mark Kovalsky
You missed the point. The point is that NEITHER solenoid can cause this.
Old May 31, 2024 | 06:12 PM
8BA Ford's Avatar
8BA Ford
4wd High
No, I caught that and I think you're right.
What do you think it would be?
Old May 31, 2024 | 06:22 PM
Mark Kovalsky
I think it is a problem with the forward clutch. It could be a leaking seal, burnt frictions, etc.
Old May 31, 2024 | 07:14 PM
8BA Ford's Avatar
8BA Ford
4wd High
10-4. Whenever I get around to tearing down the transmission, I'll try to remember to update this thread with pictures of whatever it turns out to be. Might help someone else in the future.
Old May 31, 2024 | 08:32 PM
zzyzxpat's Avatar
zzyzxpat
Very common for the forward clutches to just wear out, excessive clearance and then it cuts the outer lip seal. Also common to crack the forward drum at th esnap ring groove. Both would cause your issue.
fordexcursionlif3
Modular V10 (6.8l)
Jun 16, 2021 12:24 PM
altraditional
Jul 7, 2020 05:30 PM
Johnny Mayday
General Automotive Discussion
Mar 28, 2018 01:28 PM
JWA
Garage & Workshop
Jan 9, 2014 08:08 AM
93bigbronco
Apr 3, 2003 09:17 PM
