Steering Column Centering
Old May 26, 2024 | 06:23 PM
Larryjr03's Avatar
Larryjr03
Hi ya'all, 1950 F1 question ? WHERE would the centerline be , using the dash as the location point to center the steering column/shaft ? I am thinking directly centered between the 2 gauges . This truck has been modified before I got it, and I' m about to mount my seats, so I'd like the drivers seat , and me, to be in line with the steering wheel and shaft. Any help appreciated, and have a safe and happy Memorial Day, and special thanks to any Veterans out there. 😊
Old May 26, 2024 | 08:12 PM
smallello's Avatar
smallello
Are we there yet?
Seems like you already have the answer. Center between the gauges if that feels comfortable for you. I don't know if there is a spot where it's "supposed to be" (like a factory spec.) but that may not be the best place for it.
If it's not comfortable you will not be happy with it. I would mount it where it feels right.
Old May 26, 2024 | 08:50 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Are the bolt holes for the column drop not under the dash?
Old May 26, 2024 | 10:08 PM
Larryjr03's Avatar
Larryjr03
Yes, but there's 3 of them. 3 slots. Kinda strange, and yes they do look factory.
Old May 26, 2024 | 10:12 PM
Larryjr03's Avatar
Larryjr03
That answer does not help. It's already where someone else thought it should be. I need to know where it'ss SUPPOSED to be. Where the column attaches has everything to do with seat location. Thanks anyway.
Old May 26, 2024 | 10:30 PM
EBEAR's Avatar
EBEAR
I don't know if the f1's are similar to my f100 but to put it where the factory put it really is not great especially if you have buckets . Unless you have a bench where it's not crucial exactly where you sit .
Old May 27, 2024 | 07:46 AM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Wow
I thought he gave you a pretty good answer
You start off asking for the correct position but then say you are about to mount the seat and you want the column, seat, and you to all be in line... ...basically in a custom spot to what feels good to you. Whish is what he advised.
You also mention centered "between the two gauges". Are you sure your truck is a 1950? if so, it should have a single gauge cluster containing the 4 gauges and the speedo. The 51 and 52 trucks had the 2 separate round gauges.
Good luck with it
Old May 27, 2024 | 09:34 AM
EffieTrucker
1948-1950 gauges:
Notice the steering wheel looks to be slightly right of centered on the small gauges
1951-1952 gauges:
Notice the steering wheel is almost under the speedometer
I couldn't find a picture as straight-on as the one above
ETA, I found one a little more straight-on:
It looks to be left of center of the speedometer
Old May 27, 2024 | 09:47 AM
bhenders's Avatar
bhenders
Larryjr03,
Yes, thanks to all who have served our country ! I have had a similar situation to yours with my 51. I first "assumed" that the column should be between the two round gauges and mounted my bucket seats accordingly. (My truck was in pieces when I bought it ) Anyway, I kept thinking that my head was too close to the top of the door and that I was positioned too close to the door overall. So then I start looking at pictures and realized the steering column was always 2-3 inches to the right of that point between the gauges. ( I agree the openings for the column drop leaves much to the imagination, one opening is a more of a slot than a hole.)
So I welded the holes I made in the floor up and am now starting over, with the intention of the column to the right of the center point of the 2 gauges. In short, try to find some pictures of what the original set up was. I would happily send you some pictures of mine, but nothing is in place.
The responders that said, go with what is comfortable have a point. I was not comfortable being that close to the door, so moving a little to the right !
Lets all enjoy these terrific trucks !
Old May 27, 2024 | 09:50 AM
bhenders's Avatar
bhenders
Thanks EffieTrucker, I think we must have been on line about the same time, so I had not seen your pictures when I sent my response ! The pictures tell the story.
Old May 27, 2024 | 10:04 AM
EffieTrucker
It has always bothered me how our F-100s steering wheel and gauges don't line up. The steering gear bolted to the frame dictates the alignment.
A little right of center
Old May 27, 2024 | 10:07 AM
Larryjr03's Avatar
Larryjr03
Originally Posted by bhenders
Larryjr03,
Thank you very much. Pictures are great ! Yes, truck is a '51-'52. Another item that comes into play is Steering Wheel. My truck is not/will not be stock, IFS, P/S etc......so I don't have huge factory steering wheel to contend with, sorry, I should have mentioned that in my post. I also would like to keep my column, shaft etc. as close to the frame as I can. I think centered between the two gauges will work. Thanks again for all responses. P.S. Bucket seats I have are very close to the doors, not a lot of wiggle room there either.
Old May 27, 2024 | 10:10 AM
52 Merc's Avatar
52 Merc
Old May 27, 2024 | 10:15 AM
mtflat's Avatar
mtflat
Me? I'm just sitting here for the show as the OCD and the Close Enough for Who it's For camps line up to do battle.
Old May 27, 2024 | 12:30 PM
EBEAR's Avatar
EBEAR
You need to decide what is more important to you , everything being centered or getting it so you are comfortable . I spent days with my f100 column , seats and pedals compromising to get things where I felt it was decent . If the steering wheel is centered to the gauges and the seat centered to the wheel the buckets would be touching in the middle with 10"s or more from the door to the edge of the seat leaving it looking ridiculous .
Red60
20
Mar 23, 2022 04:08 AM
union_guy
Apr 26, 2021 09:41 PM
hombre292
Dec 9, 2012 09:30 PM
flip4eva83
Jan 15, 2012 08:31 PM
19Seventy7HiB0y4x4
16
Mar 20, 2002 09:12 PM
