trans options for my 69 e100
Old May 26, 2024 | 01:58 PM
scottscheffer55's Avatar
scottscheffer55
Hi all,
I'm pondering ways to get better gas mileage with a trans and rear-end conversion of some sort. It's currently a three on the tree with a 302. Some have recommended a t5, but I think the shifter might be an issue. Where would I put a floor shifter with the doghouse taking up all the acreage where a floor shift would normally be? Another possibility would be a good automatic. I'd love to hear about other people's experience with this, with info about what gears go well with whatever trans might be a good option. I'm just musing about this as a fairly distant future project and thought I'd start gathering information and suggestions.
Thanks a lot
Scott
Old May 26, 2024 | 02:25 PM
tabijan's Avatar
tabijan
What mileage do you get now and what do you hope to get? What do you carry in the van? Are you in a hilly area? Current diff ratio?
Sixto
07 E350 5.4 198K miles
Old May 26, 2024 | 03:04 PM
scottscheffer55
I haven't really driven it much yet. Just been fixing stuff and moving it back and forth across the street. I totally rebuilt the 302 and it runs beautifull.Fixed some wiring issues. I'm assuming it's not great on gas - it's an E100 cargo van with a 302 and three on the tree, so I'm thinking it gets somewhere between 14 and 16, but it's all just speculation and musing at this point. But I would like to put some miles on it. I live in LA and it would be nice to take some recreational drives.and somewhat decent gas mileage would be nice and a nice cruising speed would be great too. Not looking for miracles but want to start exploring some options without going too crazy.
Old May 26, 2024 | 06:28 PM
tabijan's Avatar
tabijan
You might try a 3.42 rear if it isn’t that already. Taller gears and you’ll be downshifting for every incline. Vans are heavy empty.
Is there a 4-speed that’ll use the same column shifter? Thats about what’ll get better fuel mileage.
Experts can describe what it takes to retrofit an overdrive automatic with lockup. I think they all require some electronics but it could be a simple switch or aftermarket module. It might be more pleasant to drive but I doubt an automatic with overdrive and lockup will get significantly better fuel mileage than your 3-speed. What you’ll spend converting will buy years of gas.
Sixto
Old May 26, 2024 | 09:07 PM
scottscheffer55
The 4 speed using the column shift is really interesting. I've heard there are ways to use all 4 positions for forward gears and a gizmo you attach somewhere else to get into reverse. Thanks a lot for the response!
Old May 27, 2024 | 06:01 PM
Conanski's Avatar
Conanski
An AOD would be a relatively easy swap, it's got a really deep 0.68:1 OD ratio which lends itself to using 3.55-4.10 gears for better overall performance
Old May 28, 2024 | 01:56 PM
maples01's Avatar
maples01
Originally Posted by scottscheffer55
Hi all,
Thanks a lot
Scott
Mine had 3.25 gears, a stick in the floor looks stupid as it comes in behind your seat, as for AOD they depend on a throttle cable, and just the slightest misadjustment will burn the transmission up, they just don't last long because the cable stretches and isn't adjusted as it stretches to correct it. I can tell you no matter what you do, you will have little to no impact on mileage, how much hwy driving over 55 do you do, because that is where it matters, its a brick, wind resistance is high.
Old May 29, 2024 | 08:03 AM
manicmechanic007's Avatar
manicmechanic007
A few things to think about
You are not going to improve a 1969 carbureted vehicles gas mileage much
There are a few things you can do
Add overdrive
Lower the float level a tad (use the low end of the spec in a carb kit chart)
Use slightly smaller jets
Have somebody go through the carb and verify the power valve is good (unless you can do that yourself)
Have an I/M test done and check the CO (have them give you a printout of the HC and CO numbers in manual mode)
That CO will be 10 percent with a leaking power valve and will cause real bad fuel mileage
Old Jun 4, 2024 | 10:35 PM
scottscheffer55
That is really helpful. Thanks a lot. Very much appreciated.
One79one71
Jan 3, 2017 10:35 AM
71OldFordTruck
Feb 2, 2009 05:41 PM
jimbob21rc
Feb 25, 2008 09:29 AM
inliner
May 14, 2003 06:03 AM
