Intake manifold gasket or thermostat housing leaking.
I have a 2009 F-150 with the 4.6 liter. Truck currently has 220,000 miles. I started having a coolant leak that appeared it was coming from between the engine and transmission. Based on this forum and others, it sounded like a sure sign of the intake manifold gasket being bad. Upon inspection, it looked more like the thermostat housing was leaking and coolant was being blown back towards the rear of the engine. And only the driver side of the of the motor was wet with coolant. However, after removing the bolts to the thermostat housing, I noticed the shafts and the threads were extremely rusty and corroded, and they were very difficult to remove. This is making me think that maybe the intake manifold gasket is in fact bad and I should bite the bullet and replace it. Looking for input before digging in further on this one. Thanks in advance.
That’s exactly what I’m anticipating being the cause. Going to go ahead and tear it down to the intake manifold and start ordering parts.
This is what we used at the dealer. Works great and won't damage the aluminum decks. 1 disk should be enough, you may want more for other projects in varying grit. You'll also need the quick change adapter to use it with a drill.
The following users liked this post:
Rusty1533
11-27-2006 06:41 AM
peteyg
04-22-2004 03:57 PM
