Intake manifold gasket or thermostat housing leaking.
Old 05-20-2024, 06:22 AM
BigBlue92's Avatar
BigBlue92
BigBlue92 is offline
I have a 2009 F-150 with the 4.6 liter. Truck currently has 220,000 miles. I started having a coolant leak that appeared it was coming from between the engine and transmission. Based on this forum and others, it sounded like a sure sign of the intake manifold gasket being bad. Upon inspection, it looked more like the thermostat housing was leaking and coolant was being blown back towards the rear of the engine. And only the driver side of the of the motor was wet with coolant. However, after removing the bolts to the thermostat housing, I noticed the shafts and the threads were extremely rusty and corroded, and they were very difficult to remove. This is making me think that maybe the intake manifold gasket is in fact bad and I should bite the bullet and replace it. Looking for input before digging in further on this one. Thanks in advance.
Old 05-20-2024, 09:36 AM
RLXXI's Avatar
RLXXI
RLXXI is online now
Mr. Electric
Received 1,394 Likes on 1,103 Posts
Those manifolds are known to bust right behind the alternator if its the all plastic one. There's also a coolant pipe in the valley below the manifold that's known to leak.
Old 05-20-2024, 08:00 PM
BigBlue92's Avatar
BigBlue92
Originally Posted by RLXXI
Those manifolds are known to bust right behind the alternator if it’s the all plastic one. There's also a coolant pipe in the valley below the manifold that's known to leak.
That’s exactly what I’m anticipating being the cause. Going to go ahead and tear it down to the intake manifold and start ordering parts.
Old 05-22-2024, 06:36 PM
BigBlue92's Avatar
BigBlue92
Think I found my leak.
The following 3 users liked this post by BigBlue92:
Old 05-23-2024, 09:43 AM
BigBlue92's Avatar
BigBlue92
Looks like I’ll be replacing the intake itself as well.
The following 2 users liked this post by BigBlue92:
Old 05-23-2024, 11:29 AM
RLXXI's Avatar
RLXXI
RLXXI is online now
Mr. Electric
The replacement should have an aluminum front runner, the part that usually busts on the plastic manifolds. Well the Ford replacement does, couldn't say on aftermarket parts.
Old 06-07-2024, 03:13 PM
BigBlue92's Avatar
BigBlue92
Currently cleaning/prepping the mounting surfaces. How clean do they need to be and what are the best techniques for prepping these without causing any damage?
The following users liked this post:
Old 06-07-2024, 04:46 PM
RLXXI's Avatar
RLXXI
RLXXI is online now
Mr. Electric
How clean? Think finely machined surface for best results, you're mating a soft squishy o ring between metal and polymer. There's a little leeway but not much.
This is what we used at the dealer. Works great and won't damage the aluminum decks. 1 disk should be enough, you may want more for other projects in varying grit. You'll also need the quick change adapter to use it with a drill.
PJWhelan
1999 to 2016 Super Duty
01-27-2022 10:42 AM
hman108
01-14-2018 05:54 PM
Frdtrkrul
10-30-2017 12:10 AM
Rusty1533
11-27-2006 06:41 AM
peteyg
04-22-2004 03:57 PM
Quick Reply: Intake manifold gasket or thermostat housing leaking.
