1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Need to tow a single car trailer & car, what do I need?
Old 05-18-2024, 12:45 PM
CTcollector's Avatar
CTcollector
CTcollector is offline
7th Gear
Looking to buy a used f250 or 350, just need something that can pickup one car at a time with a single car trailer. will a gas 2012-207 single cab be enough? Looking to not spend too much, as It would be only used for that purpose.
Old 05-18-2024, 01:19 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is online now
Received 1,075 Likes on 828 Posts
There is an entire sub forum that may help
https://www.ford-trucks.com/forums/forum289/
Old 05-19-2024, 02:49 AM
jmtbiggin's Avatar
jmtbiggin
jmtbiggin is offline
Any superduty will do that well.
The following users liked this post:
Old 05-19-2024, 07:53 PM
Jon Does's Avatar
Jon Does
Jon Does is offline
8th Gear
Any Super Duty F250 will do the job.
My 05 F250 with the 3 valve engine tows my race car & trailer easily.
Old 05-19-2024, 08:20 PM
edjunior's Avatar
edjunior
edjunior is offline
Yep. Any one will do. But good luck finding a single cab. They are pretty rare in the land of Crew Cabs.
Old 05-20-2024, 07:06 AM
99powerstrokedF250's Avatar
99powerstrokedF250
99powerstrokedF250 is offline
As the guys above have said, any SD will get the job done. You're probably going to end up with a work truck (XL) if you're looking for a single cab, though from the sounds of it that wouldn't necessarily be an issue for you. For what you're trying to do, any motor would be fine so long as it's been cared for and runs good.
If you aren't going to be traveling at high speeds or long distances, if you loaded it properly you could possibly get away with an F150 but I do NOT recommend it.
Old 05-20-2024, 09:00 PM
edjunior's Avatar
edjunior
edjunior is offline
Here's my old 2003 with the 5.4L. It pulled this car like it was nothing. That was a great truck.
Old 05-22-2024, 03:07 PM
redford's Avatar
redford
redford is offline
Received 1,631 Likes on 955 Posts
My old 2007 F-250, with a 5.4L V8 and 3.73 gears, towed a 28 foot enclosed car hauler, loaded with an early 1960s full size Pontiac, all over the US, without any issues.
You won't win any drag races, your fuel economy will be abysmal, but you'll safely get the job done.
Old 05-22-2024, 10:13 PM
Eman85's Avatar
Eman85
Eman85 is offline
Towing it can be accomplished with most any pickup. Stopping it is where the need for a bigger truck comes in, including good brakes on the trailer. The longer the wheelbase the smoother it will ride.
Old 05-23-2024, 08:38 PM
Grease Super Duty's Avatar
Grease Super Duty
Grease Super Duty is offline
2nd Gear
My '99 V10 F250 SD pulled a 8x24 cargo trailer loaded to 10,000 lbs without much trouble, though a "load leveling hitch" and independent brake controller were must have add ons. I also bumped the shocks up one level in stiffness (according to the Monroe catalog at the time) and I put about 1,000 lbs in the truck bed so that the truck and trailer were closer to the same weight.
Turns out pulling a heavy trailer is not a problem for a 3/4 ton truck, and it's much more stable than the 1/2 ton. The challenge is stopping the rig...that's where the SD's larger brakes, teamed with brakes on the trailer axles (the cargo trailer was tandem axle with brakes on both axles) made a huge difference.
Old 05-23-2024, 11:58 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is offline
One car on a car trailer is going to be less than 7,000lbs. Might be as little as 4,000.
I'd say a V8 or ecoboost F150 will suit your needs as well. But any super duty will handle it well.
Old 05-25-2024, 08:37 AM
F2shiitty's Avatar
F2shiitty
F2shiitty is offline
There’s so many single cab gassers up in new England where I live, many many crew cabs too lol but there’s definitely more than a few
AZFordLover
2017+ Super Duty
24
06-18-2021 08:40 AM
brandon4
2017+ Super Duty
06-14-2021 05:32 AM
tndiesel
01-01-2008 12:26 AM
Munky
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
05-21-2006 09:39 PM
Quick Reply: Need to tow a single car trailer & car, what do I need?
