Led Bulbs
Old 05-17-2024, 08:11 PM
4rkids's Avatar
4rkids
4rkids is offline
4wd High
Led Bulbs
Help I swapped out the regular head light bulbs to LEDs worked great for awhile then they would not come on unless i did the flash the high beams then they would come on now they don’t come on at all any ideas
thank you
Old 05-22-2024, 07:48 PM
Rainmaker1's Avatar
Rainmaker1
Rainmaker1 is offline
Swap back to your original halogens and see if they work. If so, you might have a resistance problem, or lack of in this case. LED bulbs draw much less current than halogens or incandescent. When I installed led backup bulbs, everything worked fine but once I added a license plate backup light for more light, my backup sensors went wacky. Once I added a load resistor to each light, the problem went away. The led tail lights did the same thing.
Hope this helps.
Old 05-24-2024, 07:33 AM
4rkids's Avatar
4rkids
4rkids is offline
4wd High
Thanks yeah I did that nothing so now im in search of a headlight switch
Old 05-24-2024, 12:09 PM
Rainmaker1's Avatar
Rainmaker1
The last I heard the OEM headlight switches were no longer available. I believe aftermarket replacement switches are available. Be sure to get the right one as there are a couple different part numbers based on year and if you have fog lights or not.
Old 05-24-2024, 03:28 PM
4rkids's Avatar
4rkids
4rkids is offline
4wd High
Yeah I see all that
crazy ford would do this to us 🤦🏽
Old 05-24-2024, 03:34 PM
01__Excursion's Avatar
01__Excursion
01__Excursion is offline
Have you checked for power at all points? Headlight plugs, headlight switch in/outputs?
Old 05-25-2024, 01:33 AM
4rkids's Avatar
4rkids
4rkids is offline
4wd High
No I have not
Old 05-25-2024, 05:13 AM
01__Excursion
Your profile says you're a 2001,
This is from the 2001 book, no DRL option.....
Old 05-25-2024, 11:39 AM
4rkids's Avatar
4rkids
4rkids is offline
4wd High
Ong thank you so very much I will find somebody that can look at this to help me figure this out need to be able to drive at night again
RV_Tech
Slide-in / Truck Campers
02-13-2023 04:21 PM
Denola
1999 to 2016 Super Duty
09-01-2015 07:03 PM
MirageVT
07-15-2006 12:29 PM
yyz87
Appearance & Dress-Up
08-07-2003 04:35 PM
Quick Reply: Led Bulbs
