Led Bulbs
Old May 17, 2024 | 08:11 PM
4rkids's Avatar
4rkids
4wd High
Led Bulbs
Help I swapped out the regular head light bulbs to LEDs worked great for awhile then they would not come on unless i did the flash the high beams then they would come on now they don’t come on at all any ideas
thank you
Old May 22, 2024 | 07:48 PM
Rainmaker1's Avatar
Rainmaker1
Swap back to your original halogens and see if they work. If so, you might have a resistance problem, or lack of in this case. LED bulbs draw much less current than halogens or incandescent. When I installed led backup bulbs, everything worked fine but once I added a license plate backup light for more light, my backup sensors went wacky. Once I added a load resistor to each light, the problem went away. The led tail lights did the same thing.
Hope this helps.
Old May 24, 2024 | 07:33 AM
4rkids's Avatar
4rkids
4wd High
Thanks yeah I did that nothing so now im in search of a headlight switch
Old May 24, 2024 | 12:09 PM
Rainmaker1's Avatar
Rainmaker1
The last I heard the OEM headlight switches were no longer available. I believe aftermarket replacement switches are available. Be sure to get the right one as there are a couple different part numbers based on year and if you have fog lights or not.
Old May 24, 2024 | 03:28 PM
4rkids's Avatar
4rkids
4wd High
Yeah I see all that
crazy ford would do this to us 🤦🏽
Old May 24, 2024 | 03:34 PM
01__Excursion's Avatar
01__Excursion
Have you checked for power at all points? Headlight plugs, headlight switch in/outputs?
Old May 25, 2024 | 01:33 AM
4rkids's Avatar
4rkids
4wd High
No I have not
Old May 25, 2024 | 05:13 AM
01__Excursion
Your profile says you're a 2001,
This is from the 2001 book, no DRL option.....
Old May 25, 2024 | 11:39 AM
4rkids's Avatar
4rkids
4wd High
Ong thank you so very much I will find somebody that can look at this to help me figure this out need to be able to drive at night again
RV_Tech
Feb 13, 2023 04:21 PM
Denola
Sep 1, 2015 07:03 PM
MirageVT
Jul 15, 2006 12:29 PM
yyz87
Appearance & Dress-Up
Aug 7, 2003 04:35 PM
