Automatic transmission position pointer, is it supposed to have a return spring?
Old May 14, 2024 | 07:34 PM
karljay's Avatar
karljay
Update:
Never mind about the indicator, found a great picture, it does have a return spring:
https://bluetruckparts.com/products/ic87r
Still wondering what that funny storage space thing is for.
After working with the column, the indicator is pretty far off. I see it's a pull cable, so does that mean it has a return spring inside the gauge cluster?
BTW, what is that square dash storage box for? It's an odd shape. it's the one below the tach, about 3" x 4" and has ridges inside. Looks like it gets smaller as it goes back.
Old May 14, 2024 | 10:53 PM
renwOdroF's Avatar
renwOdroF
4wd High
There is an adjustment wheel not shown in your pic to adjust the bar to the appropriate gear selected. That little cubby hole I use for gas cards or dump cards. I also used mine for my trans programmer so I can change the shifting pattern of my trans on the fly. In case I find something heavy to carry in the back while at the swapmeet
Old May 15, 2024 | 12:16 AM
karljay's Avatar
karljay
But it has these little rail things along the top. It's made for something specific.
Old May 15, 2024 | 12:45 AM
Soup bean's Avatar
Soup bean
The top is made to hold coins.
Old May 15, 2024 | 06:27 AM
renwOdroF's Avatar
renwOdroF
4wd High
You sir are correct.
crabjoe
Sep 21, 2011 11:02 AM
ghunt
Feb 17, 2009 10:23 PM
natewoz
Jun 4, 2008 06:27 PM
rhino_160
Dec 23, 2007 10:35 PM
