Transmission selector broken.
Old Jun 2, 2008 | 08:22 PM
natewoz's Avatar
natewoz
This morning the gearshift selector on the '93 made a popping noise, and I believe the spring that adds tension to it broke off some how. The selector also only gives me N, OD, 2, and 1.
I'm gussing this is going to be a junkyard fix. Has this happend to anyone else, and if so how did the fix go? Thanks
Old Jun 2, 2008 | 08:40 PM
danr1's Avatar
danr1
One big "Pop" like something broke?
You may have broke the "shift tube", tends to be a dealer item but you may get lucky and find a good one in a bone yard.
Common problem in em, easy fix if thats the problem, just need to drop the column down some from the dash to change it.
Old Jun 3, 2008 | 06:02 PM
alz's Avatar
alz
The indicator is attached to the instrument cluster. It can be removed with 2 screws IIRC. There is a little spring that does hold tension on the string that has the indicator on it. Open it up and see what you need. If it's only a spring, I'm sure you could source one from a hardware store.
Old Jun 4, 2008 | 06:27 PM
lostin90s's Avatar
lostin90s
Yep replaced them before.
