Wait to Start - Doesn't Start Question
Old May 14, 2024 | 01:28 AM
Chowdur's Avatar
Chowdur
1st Gear
Recently purchased a 2001 7.3 with 185k miles, first Excursion and first diesel vehicle.
If I turn the ignition on and wait for the "Wait to Start" light to go out before cranking (usually about 5 seconds) the truck has a 50/50 chance of starting. On the times it doesn't start it acts like a dead battery when you turn the key. If this happens it can take multi tries before you can hear the starter crank the motor.
If I turn the ignition on and crank immediately, the truck starts every time.
Any ideas what could be causing that? Is it bad to cold crank the truck every time?
Thanks for any input.
Old May 14, 2024 | 07:25 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Pull your batteries out of the truck, let them cold soak over night and have them load tested. They may not be able to stand up to the demand of the glow plugs.
OR you could disconnect the GPCM, Wait to start, then see if it does it. If it acts up, the glow plugs are more than likely sucking too much juice.
Old May 17, 2024 | 02:34 PM
oharal's Avatar
oharal
99.999% of the time it acts like it has a dead battery it's because the batteries are dead. Not to sounds like a peckerhead but that's usually just how it is.
Kai Herrmann
Jun 25, 2021 09:18 PM
Jerre Hurst
Jul 14, 2020 02:57 PM
my76f2fiddy
Dec 5, 2019 11:47 AM
chetspencer
Apr 15, 2012 11:55 AM
hdb454
Jul 5, 2006 07:33 PM
