Sponsored by: Real Truck
Starting issue?
Old Jul 14, 2020 | 02:57 PM
Jerre Hurst's Avatar
Jerre Hurst
Starting issue?
I have a 2009 f350 with the 6.4 diesel with approximately 160k miles. Recently I have had a situation where the truck fires right up and runs like a top but after you turn it off it wont start again until it sits for an hour or so. If you try to start it immediately after turning it off it turns over but wont crank. Strong new batteries and starter replaced. The alternator is charging and the fuel filters were clean. It felt like it wanted to cut out just before I got home. Also,the engine will continue to turn over even if you aren't touching the ignition
